1 - 3 of 3 Posts
Ok, everything is off (I've done it a million times) but I can seem to figure out how to seperate the little adjuster dials for the air vents from the dash? Does anyone know, I know they come off but I don't want to reak anything! Thanks!
Re: Taking Apart Dash Help (1996eurogti)
have you invested in a manual....finding the right manual usually tells you how to take your car apart and put it back together again.....anyways, mine just pull right out
You need to pop out the vents themselves to access the screws that hold the panels in place. Use a set of needle-nosed pliers and pop each side of the vent out very carefully and the vent will be free allowing you to access the screws that hold the "vent panel" in place..
1 - 3 of 3 Posts
