1 - 11 of 11 Posts
So I bought my buddy's 2.0L turbo rabbit last week. It was misfiring badly and he was fighting a lean condition. First thing I did was replace the plug wires to fix the misfiring issue. I just had a 2.5" turbo-back exhaust built today and now all I have left to do is figure out why I'm going lean under boost. It happens usually when I put a big load on the turbo....say 2nd gear at 2k RPM's at near to WOT. It goes lean (according to the AF gauge) and cuts out completely. Here's what I know about the turbo setup.
Digifant 1 ECU/harness from a G60
Stock G60 injectors and FPR
CIS fuel pump
T3 (looks like the same one 2kjettaguy is running - I think it came off a Thunderbird)
I'm running 5-7lbs of boost most of the time according to the gauge (it read as high as 9lbs from a pull in 4th gear on the way home.) What could be causing my lean condition? I'm new to turbos, so please bear with me.
Modified by jerk at 5:27 PM 7-1-2003
Re: Taking over a turbo project....running lean. (jerk)
whats the co_pot set to? check the resistance between the two outer prongs, shoudl be around 450 - 500 ohms.. next is it a 8v or a 16v? also do you have a chip for it? if so ask the chip company about the problem
Discussion Starter · #4 ·
Re: Taking over a turbo project....running lean. (smash929)
I checked the CO pot (it was at 561) and set it back to 499-501 as I wasn't able to get it dead on to 500. To answer the 2nd question....8v crossflow head.
probably need to put the 3.5bar and correct chip on it.
Make sure your not hitting digifant lag.. thats a motha
sell it to me
Discussion Starter · #6 ·
Re: Taking over a turbo project....running lean. (mrkrad)
Where would I get those and what's digifant lag?
and..... no!
He's not allowed to sell it. At the price he's paying for it, it's more like he's renting it for a year or two.
And yes chad, you will need to buy a chip from mkrad sooner or later.
Re: Taking over a turbo project....running lean. (sirhc)
Defintly need a 3.5 bar FPR, and a anti lag SNS chip (Mrkrad). you get those 2 and your set http://****************.com/smile/emthup.gif
Discussion Starter · #9 ·
Re: Taking over a turbo project....running lean. (I Wuz BottlFedG60)
What about a 4bar? I pulled a 4bar off a Corrado VR6.
Mrkrad had a nice little write up on how to mod your stock fpr to any bar you want damn that guy is so smart http://****************.com/smile/emthup.gif
Re: Taking over a turbo project....running lean. (wolf rocco)
Quote, originally posted by wolf rocco »
Off the mad scientist Website
http://snstuning.com/fpr.htm
1 - 11 of 11 Posts
