1 - 5 of 5 Posts
me and another guy are going to swap trannys he has a 5spd i have an auto...
what do we need to take of each others car to get it all done?
Re: tanny swap (SA Golf)
A LOT... I'd suggest getting a Bentley, it's a huge job you're talking about there, and it'll go into huge amounts of detail as to that sort of procedure.
If it were me, I'd just trade the cars
I mean, it's possible to do, but it's just so involved, its' infinitely easier just to swap keys
Re: tanny swap (jazzbass240)
i have bentley... i know this is a big job.... all i need is a list of things we need to trade...
i did a search and found some things for the Auto to 5 Spd swap
manual trans
starter
throttle body from manual car
throttle cable & bracket from manual car
mk2 pedal cluster w/clutch
clutch cable
shifter assembly
all the linkage and hardware for the under shift linkage
clutch set
flywheel
9 new flywheel bolts
front motor motor bracket
but i am haveing trouble finding what i need for the 5spd to auto swap...
is it just basicly the parts needed to be replace in the auto to 5spd?
Modified by SA Golf at 7:00 PM 2-17-2004
5spd to auto.... first, why? the auto trannies are notoriously horrible, bad shifting, poor mileage, no power, etc etc, and they like to crap out on peopel, leaving you with either needing a rebuild ( which never last), or another used tranny, which will crap out as well.
anyways, you will need the tranny, auto shift box and cables with the starter kill, starter itself, throttle body and throttle cables, torque converter, that's all i can think of off the top of my head to do 5spd-to-auto.
1 - 5 of 5 Posts
