TB removel Q?
663 Views 3 Replies 4 Participants Last post by  G60247
i want to take my TB off to P&P it. i was just wondering if there is anything that i should be careful with and look out for? also when removing it any helpful hints that someone might have to share that might make things easier? any info will really help, thanks http://****************.com/smile/emthup.gif
See less See more
1 - 4 of 4 Posts
Re: TB removel Q? (back in black)
nothing special, unhook the throttle cable and switch connectors, just remove the 4 hex head bolts, then the whole thing will come off, then to seperate the boost return valve there are 2 torx screws, now you will have to unhook the boost return valve linkage just be sure not to break the plastic connectors.
Re: TB removel Q? (brilliantyellowg60)
there is the bracket for the fuel sensor it attaches to the 2 of the TB bolts and to cylinder head if the car wasnever taken apart or if it was put back together properly. this can be the wors part of the TB removal. carefull not to lose that throttle cable clip.
1 - 4 of 4 Posts
