This TB (Technical Bulletin) describes a software change for the instrument cluster that will be automatically carried out by your VW dealer the next time you 2007 Eos is in for regularly schedule service, such as an oil change.
It is a very simple procedure to carry out - it only takes a few minutes to do, and does not result in any visible change to any component in the car. No dis-assembly is needed, the work is done using a diagnostic scan tool.
The result of making this software change is that the speedometer of your Eos will be a bit more accurate. Because the speedometer over-reads a tiny bit prior to making this change, there is no great urgency attached to getting the change made. I have no idea how much the speedometer over-reads prior to carrying out this TB, but my guess (based on experience with other VW products) is that the inaccuracy is very small - probably it is currently over-reading by 1 or 2 MPH, maximum, when you are driving at highway speeds.
If you have not already done so, please read the Eos forum post entitled Eos Technical Bulletins (TB) - Philosophy, How to Use, Index. This is essential reading for all VW owners who are curious enough to be reading TBs - it explains the philosophy and etiquette involved in TBs.
Michael
Michael
