OK, So I was driving out from phoenix yesterday to las vegas and a problem happend. After i was cruising along at about 80 or 90 or 100 for about an hour and a half i came to a steep grade. At this point the engine temp was still 190 and stayed the same forever. But when i came to this steep grade, i just starting lossing speed. Lots of speed. From 80 down to about 40 in 3rd gear with about 3k rpm. I then pulled over and checked oil levels and opened up the fill hole. The oil level was a little low, but some smoke came out of the fill hole, not a lot but enough to worry me. So i filled it with some oil i had in my trunk 5w-40 syn cumming oil. The same stuff i use for oil changes. We shut the car down and let it cool down for about 10 min keep going. When i turned it back on it sounded like there were no turbo noise, which would make sense if the turbo died, i would have no power. Anyways, we kept going, about 2 miles later the check engine light came on, We pulled over and let it cool down for about 40 min. We turned it back on: Turbo noise and Turbo power! We decided to turn around and not risk getting stranded in the desert. The whole way home it ran fine, we were just crusing with low trottle pressure. Once we got home the check engine light had gone away.
Tell me if i'm wrong this is one of the two things i think could be happening.
1. High temp oil induced excessive oil pressure. Which the ECU picked up on. Rather than risking distroying the turbo, the computer lowerd boost pressure to a min. Or turned the turbo off. When the Oil temp went town i recognized that the pressure was lower to and "restarted" The turbo.
2. High oil temp, and light weight oil at high temp caused a lack of lubrication between the turbo shaft and the bearing, it seized up and stopped working. The computer recognized that boost pressure was wrong and turned on the check engine light. After cooling down and restarting the turbo worked but the bearings were screwed up, so it basically limped home.
Its a 2000 TDI runs 5w40 oil in Phoenix AZ it runs fine for short trips like city driving. This problem only occured after running for hours and hours at a high speed in the desert. It has 75k on it too.
I would Vag com it, but don't have a vag com yet or else i could see why the check engine light came on. Since i got home it hasn't been run.
