1 - 20 of 35 Posts
okay.. i recently had my hidden tip switched with the 4-motion pipe.. and then their oval exhaust.. however the guy had problems getting the pipe to fit up in my 337 rear valence..
I was wondering if you guys had problems with this.. here is an ugly picture of what it looks like.. as you can see, it sits down an inch too low... should i have them make a custom pipe?
Re: Techtonics exhaust people.. Those with the 4-mo pipe.. (fitch)
quote:[HR][/HR]if i were you i would, i would also get a dual pipe http://****************.com/smile/emthup.gif [HR][/HR]​
wont fit in the 337 hole.. atleast with any decent size dual pipe..
Re: Techtonics exhaust people.. Those with the 4-mo pipe.. (WARCHILD...)
Thank you! if you look at the 4-mo pipe.. does it incline up or down.. they put mine down.. and i think it is supposed to go up..
Discussion Starter · #7 ·
Re: Techtonics exhaust people.. Those with the 4-mo pipe.. (SoFlaJetta)
quote:[HR][/HR]
Damn
Sorry for my "off-topicness" but that dub is baller. http://****************.com/smile/emthup.gif [HR][/HR]​
heh ditto http://****************.com/smile/emthup.gif
Re: Techtonics exhaust people.. Those with the 4-mo pipe.. (DuckyGTI)
quote:[HR][/HR]
Damn
[HR][/HR]​
WOW, that is a schweeeet dub
Re: Techtonics exhaust people.. Those with the 4-mo pipe.. (PoketRoket)
I know with the tt exhaust you have a lot of play with the mid section, hangers and all. In order to fit mine correctly, (hidden tip) I had to cut off a little bit of the exhaust tip, but there is plenty of play, moving it left, right, higher, lower. Just tinker with it.
i ordered mine to fit under the rear valence, due to my lack of a cut-out. I was under the impression that there were two different pipes, one straight and one with the bend. i think you have the bent one, but the green gti has the straight one
Discussion Starter · #11 ·
Re: Techtonics exhaust people.. Those with the 4-mo pipe.. (silver2point01)
quote:[HR][/HR]i ordered mine to fit under the rear valence, due to my lack of a cut-out. I was under the impression that there were two different pipes, one straight and one with the bend. i think you have the bent one, but the green gti has the straight one[HR][/HR]​
there is a slight bend.. but mine is with the bend all the way down.. and it wouldnt work under the valence.. flipping it up should bring it up an inch.. which is what i want
i am going to take this to them tomorrow and be like fix it or
http://www.personal.psu.edu/users/m/g/mgb142/tips.doc
[Modified by DuckyGTI, 7:59 PM 2-4-2003]
Discussion Starter · #12 ·
is it possible to fix something that is already welded? i am scared that the shape of this tip (the part where they welded) , my effect cutting it etc to redo it..
quote:[HR][/HR]This is a TT exhaust on a 337 rear...Tip is from a muffler shop here in town.
[HR][/HR]​
tight http://****************.com/smile/emthup.gif
Thanks for the comments
, but to the question at hand. Ducky GTI, I sent you an IM under a diiferent name. I will try to post a better pic tomorrow. I hope you get it worked out http://****************.com/smile/emthup.gif When I had my exhaust done on my MK3 they wouldnt put the DTM tips close the bumper afraid that it would melt it. Did they feed you that line and think it would be to close?
[Modified by WARCHILD..., 6:17 AM 2-5-2003]
Discussion Starter · #16 ·
They fixed it!!! well sort of.. they were able to get it up in the middle somewhere, but it looks ALOT better, i am happy with it... just wish it wasnt 20 here so i could wash it and take a picture
Discussion Starter · #19 ·
Re: Techtonics exhaust people.. Those with the 4-mo pipe.. (SimonPieter2)
as you can see it is not as flush as the other.. i actually thing the real techtonics tip is longer..
in person it looks almost perfect.. this is the normal picture gap embellishment.. just like my back wheel looks like 4x4.. the gap looks much smaller in person.. but close enough for pics.. i just need it to be above 17 right now, so i can wash it up.. new valences and all..
to be Honest....if you wanna get an exhaust that comes out of a 4 motion valence, techtonics should be your last choice...I mean it looks like a beverage can or something...no offense but I feel like I can smash the tips/tip with my bare hands, if you want tips, there's milltek, and recently magna flow...I will admit techtonics is the master of stealth...but when it comes to tips, http://****************.com/smile/emthdown.gif my opinion though...who agrees?
1 - 20 of 35 Posts
