Re: Tell me about Fiat x/19 ([email protected])
I have one.
It's an '83. Bertone body tags and vin, but Fiat registration.
They are easy cars to work on. The mechanical pieces are essentially those of a Fiat 128, which is the car the VW Rabbit was patterned on, so if you know how to work on a Rabbit, you'll know how to work on an X1/9.
Thing is, with the engine in a narrow hole in the back, it can be very hard to get at things. Even simple, ordinary tasks are more difficult because of the location of the engine and the lack of maneuvering room. But there's nothing complex about the single-cam motor or the transverse, all-indirect gearbox.
One thing you should know is that if you're over 6'4", you won't fit. That's not a problem for most people, but for me it is - I only
just fit in my car, and it's a tight squeeze. I would not, however, want to drive in it for eight hours.
It's alot of fun. The handling is sharper and more raw than an MR2 and way ahead of a Fiero. The car is lighter than both of those cars as well. But the X1/9's powerplant only puts out about 85 hp in the hottest factory form. 1498cc with bosch injection. The 1290cc cars with single carbs and stock exhausts struggle to put out 65 hp. There's plenty of hot-up gear around though.
As you can guess, there are two kinds - the 1974-1978 cars with the Fiat 128's 1290-cc four, with carburetors, with different bumpers and fascias from the later cars. The early cars also had only four-speeds, in common with the 128. The 1979-1989 cars have the Fiat Strada's 1498-cc four, which is just a stroker version of the 1290 so many things are shared. These later cars gained a "fifth" gear which is really a super-overdrive for fourth - much more usable cars at high speeds. Cars made after mid-1980 had Bosch Fuel injection.
Speaking of parts, it's not really very hard to find parts for this car. It's not as easy as with a Spider mind you - almost everything is available for a Spider but many parts are not remanufactured for X1/9's. But it shouldn't be hard to find regular items. Stuff that's made of unobtanium: NOS rear struts for 1300's, chin spoiler mounts for 1500's, A-arms, metal patch panels for the nose, and a few other things you probably won't need.
There are plenty of vendors and club support is strong, plus the cars are surprisingly practical. And safe. I've even heard of somebody walking away after getting hit by a train.
Rust is the main enemy of course - they all rust - usually in the back, but the worst rust takes place in the sides of the strut towers (which are triple skinned) - it's hard to see at first and not so easy (but not horribly expensive) to fix. Anything rusting in the cowl should be viewed as a parts car, since that's nearly impossible to fix. All the other usual rust spots on old convertibles apply - and remember that this is a very strong, but highly stressed unibody - rust is dangerous.
Feel free to ask anything else.
