1 - 1 of 1 Posts
In a 98 V6 car. Changed the sensor but gauge still reads backwards. It starts out in the normal position but after 15 seconds from start it goes to full temp. Been checking resistance on the sensor and it is good. I haven't checked the plug to the cluster yet but is next on the list. Did a search and all I got was mostly gas gauge or turbo gauge.
Would a possible stuck thermostat be some of the problem? I have noticed that at 85 setting on the heat it's barely warmer than my hand just wondering but doubt it. Anybody run across this and if so what did you do to fix it. All that the Bentley say's is that the cluster needs to be replaced if the gauge doesn't read out on the tester.
1 - 1 of 1 Posts
