Status
Not open for further replies.
1 - 1 of 1 Posts
Vendor
We offer a complete line of performance motor mounts for all MKIII and Corrado SLC variations. Our line of Full Poly mounts is unlike any other poly options available. They are machined from extruded stock, not gravity cast. This results in both a more uniform product as well as a more durable one.
We highly recommend replacing the transmission mount at the same time as the other mounts. Failure to do so can result in increased vibration and incorrect positioning of the motor. The .5 works well with either a diesel hydro unit or a solid rubber G60 transmission mount. The Stage I can be used with either the G60 or our own poly mount. We recommend the Stage II should be used with our poly mount or our Delrin version.
Also, be aware that the different motors will react differently to the stages. The ABA both weighs less and is positioned differently than the VR6. In general, the ABA will experience more vibration than the VR6 with the same mounts. As such, we recommend the Stage2 should be used on ABA's for race or extreme use.
Now included in all the kits, and for all the hardware, are new German produced bolts. These new pieces are chromate plated yellow to the same specs as the factory hardware, but are a higher grade and use a standard hex head. As well we now include a pair of new rear bracket bolts with all full kits and rear mounts. Another ongoing upgrade is that we have doubled the thickness of the lower Stainless Steel retaining washer for even more strength.
All mounts are available as kits or individual pieces. The hardware provided is grade 10.9 which is much stronger than the stock bolts, those of which are prone to breakage due to age and especially with harder mounts. If ordering a single mount or piece, please specify front, rear, or upper to make sure you get the correct hardware.
[URL="http://store.blackforestindustries.com/bfistsemomoc.html"]BFI Stealth Series Motor Mount Complete Kit
Brand new, just released from Black Forest are these stealthy updgrade options for your spiritedly driven daily vehicle.
These mounts are specifically engineered to fall in between new factory mounts and our popular .5 Mounts. Shore hardness is 50A - For comparison, the OEM mounts are around 40-45A in holey hardness. These are constructed from extruded stock polyurethane and are NOT made from rubber like the factory pieces. This will ensure an extremely long product life that will not break down like rubber, while still giving added performance with factory-like comfort preserved. Included in the complete kit is a G60 solid rubber transmission mount. Stealth Mounts are Ideal for those that want improved upgrade mounts for performance without sacrificing interior vibration levels on both VR6 and 4 CYL models.
Complete kit w/trans (5pcs w/hardware) $135 BUY HERE
Front & Rear Engine Mount Kit (4pcs w/hardware) $115 BUYHERE
Single Engine Front or Side Engine Mount Kit (2pcs w/hardware) $60 BUYHERE
G60 Solid rubber trans mount $20BUY HERE
BFI Stage .5 Polyurethane Motor Mount Complete Kit
These are poly, 60A in shore hardness. They are softer than both our Stage I poly(85A) and Stage II Delrin mounts . These mounts are still a huge upgrade over the stock swiss-cheese rubber mounts. We developed these mounts for those wanting an upgrade in both performance and durability over the OEM parts, yet were still very concerned with daily comfort. For comparison, the OEM mounts are around 40-45A hardness. These mounts will provide an almost factory level of comfort in VR6 cars while offering both an increase in performance and greatly increased level of durability. Vibration is more evident in 4 CYL models.
Complete Kit w/trans (5pcs w/hardware) $145 BUY HERE
Engine Mounts Only Kit (4pcs w/hardware) $125 BUY HERE
Single Engine Front or Side Engine Mount Kit (2pcs w/hardware) $65 BUY HERE
BFI Stage 1 Polyurethane Motor Mount Complete Kit
These are poly, 85A in shore hardness. For comparison, the OEM mounts are around 40-45A hardness. BFI Stage 1’s are a huge upgrade over the stock swiss-cheese rubber mounts. Stage I is intended for a higher level of performance, over our Stage .5 and Stealth. They still offer reasonable ride quality, with some increased vibration over OEM in VR6 cars. Vibration is far more evident in 4 CYL models.
Complete Kit w/trans (5pcs w/hardware) $199 BUY HERE
Engine Mounts Only Kit (4pcs w/hardware) $135 BUY HERE
Single Engine Front or Side Engine Mount Kit (2pcs w/hardware) $70 BUY HERE
BFI Stage1 Polyurethane Transmission Mount $75 BUY HERE
BFI Stage 2 Delrin Complete Motor Mount Kit
These are Delrin, and fall in between poly and solid metal as far as stiffness goes. These mounts are available as total kits, front and pass side, or as individual front and side mounts. Delrin, like some poly versions, requires some break in time. It will take 150-250 miles for them to soften to their effective hardness. They also reguire some heat in them to soften up. And on colder days they may have more vibration at start up until driven on for a few miles. They are also self-lubricating so it will never squeak. The Stage II mounts are designed for pure performance, at the expense of ride comfort. They will hold the motor and transmission very securely and help get all the power to the ground. If you drag race or are after total performance, then the Stage II is for you. If you are concerned about vibration, then perhaps you may want to go with a less rigid mount from BFI.
*StageII rear mounts now come fully assembled in new brackets for the rear mount.
Complete kit w/trans (5pcs w/hardware) $275 BUY HERE
Engine Mounts Only Kit (4pcs w/hardware) $160 BUY HERE
Single Engine Front Mount Kit (2pcs w/hardware) $75 BUY HERE
Single Engine Side Mount Kit (assembled in a new bracket) $95
BFI Stage 2 Polyurethane Transmission Mount $115 BUY HERE
We also offer the hardware only separately:
Complete Kit: Includes all hardware for Front, Rear, and Transmission Mounts. BUY HERE
Please post, IM, or email us at: [email protected] with any Technical Questions.
BFI Motor Mount Instructions links in jpg format:
http://blackforestindustries.c...s.jpg
http://blackforestindustries.c...t.jpg
Modified by black forest ind at 5:04 PM 8-18-2009
Modified by black forest ind at 5:38 PM 8-18-2009
1 - 1 of 1 Posts
Status
