some of you have helped me before with other threads but here's what I gathered from testing my dpr tonight. Can you guy's help me disect the results and give me an idea of what I should be ranging.
Had to make a couple small adjustments to the mixture to get the car to run steadily at first... seemed like it wanted to be more rich than lean. Thinking I may need to swap my coolant temp sensor because it definitely didn't want to idle until it heated up to normal operating temp.
Plugged in the test harness and got a reading bouncing from 10-14
but found that the engine sounded like it was running best when adjusted to a range of:
6.0 - 9.4 bouncing <----good/bad?
When I leaned it out the numbers spiked to 19.9 this was with a very small adjustment!!!! Plus I gave it a minute to recaliberate but it stayed at 19.9 - turned it back to rich and it registered again. I thought it may have needed to run a bit more lean but maybe I'm wrong... seems like I'm getting a bit of smokey fuel out of the exhuast.
What should my readings be??? Specs - lightend engine internals and flywheel etc., engine made to see high rpms, slightly higher cr., pnp, header, 268 cams, enrichment module, some other odds and ends. Nothing extreme but it is made to run very hard and high rpms. Mixture range should be ?mA?
Also how can I teat my coolant temp sensor??? Haven't looked in my bentely, any heads up? I am thinking that it's the cause of my bad idle on startup and maybe some of my other issues. That's one thing I never replaced on the car and would make sense. The ISV is working 100%, o2 sensor 100%, and dpr reads fine... thinking I need to replace it. Thoughts???
No need to read the below threads unless you want to get up-to-date on the issues, symptoms, and tests that have been completed.
PREVIOUS THREADS RE: trouble shooting etc.
firing on 2 cylinders http://forums.vwvortex.com/zerothread?id=2767804
o2 sensor 16v tech forum http://forums.vwvortex.com/zerothread?id=2760864
vw special tool sledge upside my car http://forums.vwvortex.com/zerothread?id=2747091
fuel distributor go bad? http://forums.vwvortex.com/zerothread?id=2676528
Modified by BubbleBLOCK at 3:14 AM 8-19-2006
