So I've spent some time looking at the cooling options that VW have used for this transmission. The Vanagon version [090] has cooler ports in the back of the housing [or is it the front because it's mounted backwards?], the Porsche [087] has them on the side of the differential housing, and the Audi [087] has them on the back like the Vanagon [correct me if I'm wrong].
I have checked the Porsche and the cooling ports are on the torque converter drain side. That makes sense because the oil coming out of the torque converter is hotter than any other oil in the transmission. So if you could cool that oil before it gets dumped into the pan, then that is good. Since it's just returning oil, you are not messing with the pressure side of the system.
I have looked at the Vanagon/Audi and have not seen any literature that shows where the oil is coming or going. Someday I may find out but at this time the answer is, I do not know.
Looking at Transaxle Engineering site [https://www.transaxleengineering.com/3-speed-auto] they seem to tap into the drain portion of the torque converter too. If you read their site long enough you will find out where they say it's better than the factory oil cooler ports at the back of the case.
So with the TJ differential housing, where do you tap into the converter drain so you can divert that to the cooler? That is where I'm at. I believe I can drill or weld an aluminum fitting into the drain port before it gets to the transmission case. It's easy to plug the port, but not so easy to divert the oil.
So the earlier post on page 1 is not ideal since I believe they are tapping into the pressure side and the pump can only flow so much. Any pressure diverted would be pressure lost that the pump may not be able to keep up with. That and wouldn't it be best to cool the hottest oil before it gets to the pan?
More to follow and yes, pictures too.
