1 - 20 of 69 Posts
Starting this thread to get as much information about upgrading theese gearboxes as possible.
If you know anything you'd like to share, please post it here.
http://www.volkspage.net/technik/ssp/ssp/SSP_205.pdf
The 02M gearbox came in 1999 with the Golf 4 and other VWs and Audis. It differs from the previous transmissions in that it has two different output shafts. This gives different final drives for 1st to 4th gear and 5th to 6th gear.
4Motion-gearboxes came with both 4-cylinder and 6-cylinder engines. The difference between them is the clutch housing.
For the 6-cylinder boxes, one gearbox is stronger than the oter models. This is the DRP and it was delivered in Golf Mk4 2.8 l. 4Motion 1999-2000. This is maybe the best start for a transmission for high effects. Cluth housing from a 4-cylinder engine can be mounted to the 6-cylinder gearbox.
Transmissions to the 3.2-liter engines (from R32) have a weakness. The bearing on the input shaft may loosen, most often seen where a lightweight flywheel. Different companies offer a modification of this, but the gearbox must be removed to get this done. HPA is one of several that can fix this:
http://hpamotorsports.com/
Lightweight flywheel will also course problems with Peloquins and Quaiffe diffs:
http://thescirocco.com/peloquin.html
CAUTION ALL 02M Owners: Do not use a lightened flywheel on the 02M, the stock clutch and flywheel is tuned for the 02M, for weight distribution, and a light flywheel goodwill pickup harmonics from the main shaft. It sounds like the trans is about to self destruct.
The ratios for the DRP
Final drive, 4.333 for 1-4. gears, 3.421 for 5-6. provides.
1st gear 3.417, 2nd gear 2.105, 3rd gear 1.429, 4th gear 1.088, 5th gear 1.097, 6th gear 0.912.
Final drive
A common problem for vehicles with high power engines and 6-speed gearboxes is the close ratio between the gears, and the top speed suffers as well. It is possible to use the final drive from the other models, here is a selection from Bora and Sharan. Here we can get ratios that gives theoretic top speeds over 320 km/h at 7000 rpm.
FD ratio for Sharan and Bora:
With 195/45-16 tires and 7000 rpm top speed is 246 km / h.
With ERR final drive, 3.1 for 5-6 gives increases the top speed to 271.5 km/h.
With EHH final drive, 2.926 for 5-6 gives 287.6 km/h top speed.
The EFF final drive, 2.727 for 5-6 gives 308.6 km/h. top speed.
With DRW / ERF final drive, 2.615 for 5-6 gives 321.8 km/h. top speed.
Sharan transmissions with 22/27/79 teeth are EHH, EHL, FGM, FVP, FJG and FVR.
Golf and Bora transmissions ERR have FD 71/17/23 (FD 3.087) and 62/16/20 (FD 3.1).
A little bit more about ratios for different 02M boxes: http://workshop-manuals.com/volkswa...n_code_assembly_allocation_ratios_capacities/
Dogbox gearsets are supplied by multiple companies:
SQS Racing:
http://www.sqsracing.com/produkt/179:200:dgo-kit-box-02m-02q-competition-gears
PPG, Pfitzner Performance Gearbox. http://www.ppgearbox.com.au
Quaife:
http://www.quaife.co.uk/catalogue/products/qke3v
DM motorsport: http://www.dmmotorsport.com/wb/pages/english/home.php
ForceFed Engineering: http://store.forcefedengineering.com/SearchResults.asp?Cat=131
Shifting forks
This is a weak point on the 02M. The shifting forks for 1-2. gear will easily brake at high loads. Here is a fork of brass fastened with a rivet. This was 6 mm. thickness of the first models later this upgraded to 7 mm. Still it’s weak, and a common way to improve it is to use a high quality bolt and TIG weld the nut to prevent it from loosening.
The 3-4. shift fork is made in one piece, and this may breake under hard use. DM Motorsports offers a stronger fork in billet brass. The price is 400 CAD.
SQS Racing offers a billet shifting fork in high strength aluminum. The price is € 200 pluss taxes.
http://www.sqsracing.com/files/fs_files/productdetails/200/manual-02m-q_55.pdf
The shifting fork to 5-6. is riveted. This can be reinforced with a high strength bolt with the nut TIG welded. SQS Racing has developed an improved version that appears in the manual.
Here’s an article about the shifting forks issue:
http://bwperformance.com/blog/vw-02m-transmission-shift-fork-issues
Steel shift forks by USP Motorsports:
https://www.uspmotorsports.com/SteelShiftForkTransmissionUpgrade/6Speed-02M/02Q-.html
Support for 4th gear is offered by Epytec:
http://www.epytec.de/product_info.php/products_id/2142
Diffs from Quaife and Peloquins:
http://www.quaife.co.uk/catalogue/products/qdf14r-0
http://peloquins.com/products_R32.html
For engines with high power is difficult to find a suitable clutch. So far I have found two options that stand out:
Clutch Masteers have several models with different type of surface. In addition, they have two flywheel options, aluminum or steel.
02-017-TD6-AF
02-017-TD6-SF
02-017-TD7-AL
02-017-TD7-SF
02-017-B-TD-AL
http://www.clutchmasters.com/shop/?...o, 6 Speed & From Year = 2000 & toYear = 2006
For those who must have the highest outputs the Clutch Masters clutches may be too weak. DM Motorsports have developed a kit , a Tilton clutch with steel flywheel. This weighs 14 lbs. and can be supplied for both the 4 - and 6-cylinder engines. The kit costs 2800 Canadian dollars.
ARP offers reinforced bolt kit for the flywheel:
http://shop.ebay.co.uk/?_from=R40&_...3&_nkw=arp audi & _sacat = See-All-Categories
Discussion Starter #2 (Edited)
Discussion Starter #14
Got information from VRT, it's possible to get a shifting box that fits the Mk2/3 tunnel ann accepts the 02M shifting box internals.
Part# are:
6N0 711 061 A House
6N0 711 090 A Ground plate
6N0 711 611 C Choise arm
Pic of VRT's box:
I currently have a few issues with my 02M in my 2002 audi TTQ. Running custom GT2871R turbo. Had some nasty vibrations when reving up the engine (~44k miles) pulled the transmission and found all but 2 flywheel bolts backed out and the flywheel was only being held on via the transmission shaft and 2 bolts that didnt back all the way out. Replaced with a South Bend Clutch and 19lb steel single mass Flywheel (also SBC). Holds power fine now, however it is very noisy and feels like it vibrates a bit when up in the revs. possibly the issue referred to above with using light weight flywheels?
The other issue I am having is shifting between 1st and 2nd and 2nd and 3rd. If I shift to fast in upper revs it grinds. If I shift under normal driving it feels notchy when going into gear. I figured it was either the clutch not disengauging properly or possible the issue mentioned above about the shift forks and gear sets. When I am parked and put it in reverse, it doesnt like to go in right away, but it doesnt grind either. Anyone have any suggestions? This is killing it for me having plenty of power, but not being able to lay down good 0-60 times do to have to wait half a second between shifts so I dont grind.
thx
Another 02M box is the FMP. I got it off a Seat Leon V6 4Motion, somewhere between 2000 and 2002 model year, can't really remember.
FMP gear ratios:
ratio FD
1.gear 3.357 4.333
2.gear 2.087 4.333
3.gear 1.469 4.333
4.gear 1.098 4.333
5.gear 1.108 3.421
6.gear 0.927 3.421
The FMP also has the stronger metal end casing like the DRP.
The rpm drop from 2nd to 3rd on the FMP is slightly better than the DRP. It'll end up with ~200 rmp higher when putting 3rd gear.
3rd to 4th on the other hand is ~100rpm higher with the DRP. They are fairly close.
Elie
im currently doing a mk4 r32 engine swap into my mk4 2.8 4motion 2000 model,so it does have the stronger gearbox,i also have the mk4 r32 gearbox that came with the engine,which of the 2 gearbox would be a better choice as i am planing to go the turbo route as soon as everything is up and runing.thanks
1 - 20 of 69 Posts
