Well as speculated here in a few posts i thought i would make this to give all the information i could get my hands on!
The 2016 Jetta line-up becomes all turbocharged with the introduction of a new 1.4L TSI engine, replacing the naturally aspirated 2.0L 4-cylinder. The 2016 Jetta S and SE will now be powered solely by the lightweight 1.4L TSI, the same engine used for several years in the Jetta Hybrid, but without the Hybrid's electric motor and battery pack.
Compared to the former 2.0L engine, the EA211 1.4L TSI engine delivers:
•More Horsepower
•More Torque
•Higher Estimated Fuel Economy
•Lower Emissions
•Stronger Acceleration
•Better Throttle Response
The 1.4L TSI engine replaces Volkswagen's 2.0L inline-4-cylinder engine as the powerplant for Jetta S and SE trims. Transmission choices will continue to be a 5-speed manual or 6-speed automatic with Tiptronic®. Here is a comparison of both engines:
2016 EA211 1.4L TSI
2015 2.0L 4-cylinder
Layout
Turbocharged, 16V, DOHC, TSI
Horsepower
150
Torque (lb.-ft.)
162
Fuel Economy (city/hwy, est.)
TBD (manual)
28/39 (6-speed auto)
Fuel requirement
Regular unleaded
The MY2016 Jetta 1.4L TSI volume engine is expected to launch third quarter, 2015. Here's the MY2016 Jetta line-up:
•Jetta S – 1.4L TSI (new; replaces 2.0L I-4)
•Jetta SE – 1.4L TSI (new; replaces 1.8L TSI)
•Jetta Sport – 1.8L TSI
•Jetta SEL – 1.8L TSI
•Jetta GLI – 2.0L TSI
•Jetta Hybrid – 1.4L TSI/electric motor
The 1.4L TSI engine is built using EA211 modular gasoline engine matrix (Modularer Ottomotoren Baukasten) or MOB. This modular strategy provides cost efficiencies through standardization, and includes these features:
•Compact, lightweight design
•4 valves per cylinder, dual overhead cams (DOHC)
•Variable valve timing for top performance at all engine speeds
•High-pressure Turbo Straight Injection (TSI) for low emissions and efficient combustion
•Recommended fuel: regular unleaded
•Compact turbocharger designed for fast response, high torque at low engine speeds
•Crankshaft vibration damper for smoother, quieter operation
•Aluminum cylinder head with integrated exhaust manifold
•Belt-driven camshaft with automatic tensioning roller
•More Horsepower
•More Torque
•Lower Emissions
2016 EA211 1.4L TSI
Layout
Horsepower
150
Torque (lb.-ft.)
162
TBD (manual)
Fuel requirement
Regular unleaded
