1 - 20 of 90 Posts
Please correct me if I am wrong. I will edit this as we go. They are classified by size sorted in an ascending
order. All brakes pertain to the MK5 Platform.
Audi
A3 (2004+) | S3 (2006+) | TT (2006+)
VW
Golf (2004+) | Golf Plus (2004+) | GTI (2004+) | R32 (2005+) / Jetta (2004+) | EOS | Rabbit
Seat
Leon (2004+) | Toledo (2004+)
MkV brake combos for production vehicles (including most European models):
Audi S3 | Audi TT (3.2l) | VW R32
The Front brakes are 345mm x 30mm (13.38" x 1.18") Vented Rotors w/1 piston calipers
The Rear brakes are 310mm x 22mm (12.2" x .86") Vented Rotors
Part numbers: Disc: 1K0 615 301M | Carriers: 1K0 615 125 or 1K0 615 125-D | Calipers: 1K0 615 123 or 1K0 615 124 (Euro ETKA)
Audi A3 (2.0l TFSI) | Audi TT (2.0l TFSI) | VW Golf GT/I (2.0l TFSI | 2.0l TDI) | VW Jetta GLI/SE/Sport (2.0l TFSI | 2.0l TDI) | Seat Leon FR (2.0l TFSI | 2.0l TDI)
The Front brakes are 312mm x 25mm (12.3" x .98") Vented Rotors w/1 piston calipers
The Rear brakes are 286mm x 12mm (11.3" x .47") Solid Rotor
Part numbers: Disc: 1K0 615 301AA | Carriers: 1K0 615 125-C | Calipers: 1K0 615 123-B or 1K0 615 124-C
(Euro ETKA)
VW Jetta (S | 2.5l | TDI) | VW Rabbit (2.5l | TDI)
The Front brakes are 288mm x 25mm (11.3" x .98") Vented Rotors w/1 piston calipers
The Rear brakes are 260mm x 12mm (10.2" x .47") Solid Rotor
Audi A3 fwd/awd
Audi A3 fwd
The Front brakes are 280mm x 22mm (11.0" x .86") Vented Rotors w/1 piston calipers
The Rear brakes are 255mm x 10mm (10.0" x .39") Solid Rotor
Engine Configurations: (for reference. Not all are available on each vehicle)
Diesel
2.0l SDI 75hp
1.9l TDI 90hp
1.9l TDI 100hp (N/A model)
1.9l TDI 105hp
2.0l TDI 140hp
2.0l TDI 170hp
Gasoline/Petrol
1.4l 80hp
1.6l 102hp
1.6l FSI 115hp
1.4l TSI 140hp (Turbo / Supercharged FSI)
2.0l FSI 150hp
2.5l 150hp (N/A model)
1.4l TSI 170hp (Turbo / Supercharged FSI)
2.0l FSI 170hp
2.0l TFSI 200hp
3.2l FSI 250hp
FRONT BRAKE UPGRADES
Low budget Upgrades (replacement with same size)
Cross Drilled Rotors
Brembo
Slotted Rotors
Brembo
Cross Drilled and Slotted Rotors
TBD
12.6" (322mm x 32mm) Front Brake Upgrades
Movit 4 piston caliper Big Brake upgrade $
Comes with: 2 piece Rotors with cast holes and ventilation slots, aluminum hats, 4 piston calipers, brake pads, brackets, steel braided brake lines and bolts to mount the kit. The only thing that's not included is brake fluid. Black or Red calipers standard, other colors: $299 extra
Requires: unknown
Purchase from: Serious Euro Tuning | Movit
12.9" (328mm x 28mm) Front Brake Upgrades
Brembo GT Big Brake upgrade $2595+
Comes with: 2 Piece 328x28mm Slotted and Drilled Vaned Rotors, 4 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Requires: 17"+ wheels
Purchase from: Brembo
Stoptech 328x28mm Big Brake upgrade $1895+
Comes with: 2 Piece Floating Directional 328x28mm AeroRotors (comes drilled or slotted and/or zinc coated, 4 Piston ST-40 Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Purchase from: Stoptech
Stasis Monobloc4 Big Brake upgrade $
Comes with:ALCON 4 Piston Monobloc Calipers, ALCON 328mm x 28mm(14") Floating Rotors, STaSIS Caliper Mounting Bracket & Hardware, Goodridge Stainless Steel Braided Lines, Motul brake fluid, SBS Hi Performance Brake Pads
Purchase from: Stasis Engineering
13.0" (330mm x 28mm) Front Brake Upgrades
AP Racing 6 piston Caliper Big Brake upgrade $
Comes with: 2 Piece 330x28mm Slotted Vaned Rotors, 6 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Requires: 18"+ wheels
Purchase from: AP Racing
AP Racing 4 piston Caliper Big Brake upgrade $
Comes with: 2 Piece 330x28mm Slotted Vaned Rotors, 4 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Brembo GT Big Brake upgrade $1895+
Comes with: 1 Piece 330x28mm Slotted or Drilled Vaned Rotors, 4 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Eurospec Sport Big Brake upgrade $
Comes with:Eurospec 4-piston calipers, adapter brackets, pads, Goodridge stainless steel brake lines, and all mounting hardware
Purchase from: Eurospec
Ksport Big Brake upgrade $
Comes with:2 Piece 330mm Slotted Vaned Rotors, 8 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
RPI Equipped Big Brake upgrade $1895+
Comes with: 2 Piece 330x30mm Slotted and Drilled Vaned Rotors, 4 Piston Wilwood Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Purchase from: RPI Equipped
13.5" (342mm x 34mm) Front Brake Upgrades
Requires: unknown
Movit 6 piston caliper Big Brake upgrade $
Comes with: 2 piece Rotors with cast holes and ventilation slots, aluminum hats, 6 piston calipers, brake pads, brackets, steel braided brake lines and bolts to mount the kit. The only thing that's not included is brake fluid. Black or Red calipers standard, other colors: $299 extra
Requires: unknown
13.6" (345mm x 30mm) OEM Front Brake Upgrades
Audi S3/TT 3.2l/VW R32 Brake upgrade $1295+
Comes with: 345mm x 30mm Vaned w/isolated hat Rotors, 1 piston Calipers, caliper carriers, dust shields, pads and brake lines
Purchase from: Autotech | VW Dealer
13.9" (352mm x 32mm) Front Brake Upgrades
MKV Jetta/Golf/EOS and Audi A3/S3 Brake upgrade $1295+
Comes with: 352mm x 32mm Vaned directional vaned rotor rings w/aluminum rotor hats, 6 piston Porsche Cayenne calipers w/ a new bracket-less caliper mounting system, Hawk HPS pads and brake lines
Requires: 18"+ wheels (OEM Wheels require 3mm spacer)
Purchase from: ECS Tuning
14.0" (355mm x 282mm) Front Brake Upgrades
Stasis 4 piston caliper Big Brake upgrade $
Comes with:ALCON 4 Piston Monobloc Calipers, ALCON 355mm x 28mm(14") Floating Rotors, STaSIS Caliper Mounting Bracket & Hardware, Goodridge Stainless Steel Braided Lines, Motul brake fluid, SBS Hi Performance Brake Pads
Requires: unknown
Comes with: 2 Piece 355x28mm Slotted or Drilled Vaned Rotors, 4 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Comes with:2 Piece 356mm Slotted Vaned Rotors, 8 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
14.3" (362mm x 32mm) Front Brake Upgrades
Autotech/AP Racing 362mm Big Brake Kit (362mm x 32mm) $2995+
Comes with:6 piston calipers, 362mm x 32mm directional vaned rotors, lightweight 7075 aluminum rotor hats, caliper brackets, pads and brake lines
Requires: 18"+ wheels and Installation (spacers may be required depending on wheel offset)
Purchase from: Autotech | AP Racing
14.5" (370mm x 28mm) Front Brake Upgrades
Comes with:ALCON 4 Piston Calipers, ALCON 370mm x 28mm (14.5") Floating Rotors, STaSIS Caliper Mounting, Bracket & Hardware, Goodridge Stainless Steel, Braided Lines, Motul brake fluid, SBS Hi Performance Brake Pads
Requires: unknown
14.9" (380mm x 32mm) Front Brake Upgrades
Requires: unknown
Requires: unknown
REAR BRAKE UPGRADES
12.2" (310mm x 22mm) Rear Brake Upgrades
Audi S3/TT 3.2l/VW R32 310mm Rear Big Brake Kit (310mm x 22mm) $695+
Comes with:OE rotors, calipers, carriers and Mintex brake pads
13.0" (330mm) Rear Brake Upgrades
Comes with:2 Piece 330mm Slotted Vaned Rotors, 6 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Links to suppliers and manufacturers
AP Racing
Autotech
Brembo
ECS Tuning
Eurospec
Ksport USA
Movit
RPI Equipped
Serious Euro Tuning
Stasis Engineering
Stoptech
Edit history:
Added Stoptech, AP Racing
Added Movit, Statis/Alcon, AP Racing, Brembo, Eurospec
Added ECS Tuning Stage V
Added Ksport
Modified by eggroller at 8:31 AM 2-6-2008
Re: The brakes of the MK5 platform - OEM and Upgrades (eggroller)
Quote, originally posted by eggroller »
Soon:
Ecs Tuning?
Just wait, We have a few all new products coming for the MK5 that we do not have for any other make/model
Please keep in mind that the brakes on the Jetta trims, and the GLI are going to have different setups. I dont see anything listed above there, so not sure if its being accounted for.
Steve
Re: (Scuba2001)
Quote, originally posted by Scuba2001 »
Steve
GLI is the same as GTI, maybe eggroller can get that up there
oempl.us(?) also has the same R32 kit as Autotech for a bit less IIRC.
Powerslot already has part numbers listed for the GTI/GLI/A3, but it will be another 2-3 months before before they release their oem sized rotors; and oversized rotors with caliper adapter brackets.
They should already have out applications for TDI's and 2.5 VW's
EBC Brakes already have 3 types of pads and oem sized cross drilled/slotted Front and Rear rotors.
Discussion Starter · #6 ·
Re: The brakes of the MK5 platform - OEM and Upgrades (ECS Tuning-Tom)
Quote, originally posted by ECS Tuning-Tom »
Figured we could count on you to come up with something for the MK5 platform!
Keep the information coming folks! The more the merrier!!! I will edit when I have spare time and consolidate all information into the 1st post (like last time with the MK4 brakes).
Discussion Starter · #8 ·
Re: The brakes of the MK5 platform - OEM and Upgrades (meaculpa20v)
Quote, originally posted by meaculpa20v »
I thought that the R32's had two piston caliper up front.
Eric
Me too, but judging by the pictures provided in the ETKA and Autotech (link). They are now one piston.
The Front brakes are 288mm x 25mm (12.3" x .98") Vented Rotors w/1 piston calipers
Could you correct this to 11.3"x.98"? Thanks
Ray - great work to make informative topic! http://****************.com/smile/emthup.gif
While on the subject, I found this (smaller) AP racing bbk.
This can be fitted with OE 17" wheels as seen in this pic.
I could NOT find anyone actually selling it in USA though.
Only Japanese dealer so far... http://www.h-sport.jp/brakes.html
Quote, originally posted by GoogleTranslation »
AP racing carry per, rotor, bracket and [huerodopatsudo]
The mesh hose belongs. It is installing possible even with the normal wheel.
Golf 5GTI
330mm 2P rotor price 312900 Yen
Modified by JumpalTurbo5 at 11:58 AM 9-21-2006
Re: The brakes of the MK5 platform - OEM and Upgrades (AutoCrossR32)
MK4 R32's might be 2 piston, but, from what we have seen the MKV R32 is a single piston. go figure
here is a link the brake kit from the MKV R32.
By the way, it says the MKV size is 13.6" (345mm)
http://www.ngpracing.com/Merch...brake
Anyone kow if a direct upgrade can be done from the R32 V to the Gti V using only the rotors and keeping the same calipers ?
The R32 brakes are 30mm thick while the Gti rotors are 25mm, but i've heard they can be opened wider ?
Does anyone know ?
Re: (eggroller)
Does anyone know about the rear brakes of the new Leon Cupra. Are these the same as in R32; 310mm vented rotors or the same as in Golf V-GTi; 286mm solid rotors.
It's been made clear that the front brakes are the same as in R32; 345mm vented rotors w/ 2-piston calipers...???
1 - 20 of 90 Posts
