1 - 2 of 2 Posts
Moderator
Discussion Starter #1
The v6 is basically the red headed step child of the b5 world. It just never really got any mods that "wowed" anybody. The 30v has more options than the 12v, but even then the options are limited. Most people chose to add coilovers, wheels, a custom exhaust, and call it done.
If you are one of the guys who has a 2.8l and you want to know what's available, take a look below. This is your definitive list for b5 a4 2.8l performance mods.
Enjoy.
CHIPS - 30V ONLY
Unitronic - http://www.unitronic.ca/uni/content/view/43/33/ +16hp, +14ftlbs
Upsolute - http://www.upsolute.com/index....el=10 +18hp, +19ftlbs
GIAC - http://www.giacusa.com/programs.php?mpid=60 +6 to 9hp, +6 to 9ftlbs
GIAC Tip-chip - http://www.giacusa.com/programs.php?mpid=214 not for power, but for better shifting
INTAKES
LLTek, K&N, ITG - see http://forums.fourtitude.com/zerothread?id=3129384
EXHAUST
Custom. - use magnaflow 14815 muffler, resonator of choice, and 2.5 inch stainless piping.
Supersprint 30V headers, center pipes, rear sections - http://www.supersprint.com/homeuk.htm
Supersprint 12V rear section - http://www.supersprint.com/homeuk.htm
Techtonics Tuning single tip, all years - http://www.techtonicstuning.co...2.565
Techtonics Tuning dual tip, all years - http://www.techtonicstuning.co...2.566
PULLEYS
ECS Lightweight Power Steering Pulley - http://www.ecstuning.com/stage...lleys
ECS Lightweight Crank Pulley - http://www.ecstuning.com/stage...lleys
SUSPENSION
Vogtland/Bilstein Kit - http://www.purems.com/products/product.php/II=1977
Vogtland/KONI - http://www.purems.com/products/product.php/II=1005
H&R Race/Bilstein Sport Kit - http://www.kompressorkanada.ca...i.htm
Vogtland Coilovers - http://www.purems.com/products/product.php/II=664
Koni Coilovers - Quattro Only - http://www.purems.com/products/product.php/II=713
H&R Coilovers - http://www.purems.com/products/product.php/II=204
H&R Ultra Coilovers - http://www.purems.com/products/product.php/II=275
H&R Sport Springs - quattro only - http://www.bahnbrenner.com/vw_...attro
H&R Race Springs - quattro only - http://www.bahnbrenner.com/vw_...attro
Neuspeed Sport Springs - 96 - 00 FWD only - http://www.greedspeed.com/appl..._1.3R
Neuspeed Sport Springs - 01 FWD only - http://www.greedspeed.com/appl..._1.3R
Neuspeed 19mm rear sway - <A HREF="http://www.neuspeed.com/products/product_details.asp?app=18|AQ&type=2<ype=ns_euro&p_id=242" TARGET="_blank">http://www.neuspeed.com/produc...d=242</A>
Neuspeed 29mm front sway - <A HREF="http://www.neuspeed.com/products/product_details.asp?app=18|AQ&type=2<ype=ns_euro&p_id=134" TARGET="_blank">http://www.neuspeed.com/produc...d=134</A> *** sport does NOT need this
Hotchkis H-Sport Extreme Sway set 35mm front, 22mm rear - http://www.hotchkis.net/c-813-....aspx
Note: When adding or upgrading sway bars you should also upgrade your front end links to Subaru WRX rear end links from perrin, kartboy, or agency power [check eBay for best prices] and your rear end links to OE metal end links [check pureMS for best prices] or CPP upgraded end links [check KompressorKanada for a good price].
MOUNTS
AWE Drive Train Stabilizer (DTS) - http://www.awe-tuning.com/page...WEDTS
Neuspeed Lower Tie Bar - <A HREF="http://www.neuspeed.com/products/product_details.asp?app=18|AQ&type=12<ype=ns_euro&p_id=123" TARGET="_blank">http://www.neuspeed.com/produc...d=123</A>
OE rs4 engine mounts - http://www.awe-tuning.com/page...ounts
034 density engine mounts - http://www.034motorsport.com/p...d=772
APR Snub Mount - http://www.goapr.com/Audi/prod....html
034 Snub Mount - http://www.034motorsport.com/p...13899
Poly Rear Diff Mount - http://www.034motorsport.com/p...=1214
034 Density Transmission mounts - http://www.034motorsport.com/p...d=773
TRANSMISSION
Short Shifter: eBay, BBM, JHM, etc - see http://forums.fourtitude.com/zerothread?id=3459359
JH Motorsport solid linkage/solid stabilizer bushing - see http://forums.fourtitude.com/zerothread?id=3755416
Clutches: SPEC, Southbend, etc - see http://forums.fourtitude.com/zerothread?id=3364701
Unorthodox Racing Lightened FLywheels - http://www.unorthodoxracing.co...ltraL
BRAKES
S4 OE rear upgrade - http://www.rpiequipped.com/us/...=1916
RPI Equipped 11" upgrade - http://www.rpiequipped.com/us/...=1907
RPI Equipped 13" upgrade - http://www.rpiequipped.com/us/...=1660
Porsche BIG RED disk/calipers - http://www.rpiequipped.com/us/...d=504
Porsche BIG RED hardware kit - http://www.rpiequipped.com/us/...id=61
ESC Stage 1 front kit - http://www.ecstuning.com/stage...e%201
ECS Stage 1 rear kit - http://www.ecstuning.com/stage...01Rv2
ECS Stage 2 v1 kit - http://www.ecstuning.com/stage...e%202
ECS Stage 2 v2 kit - http://www.ecstuning.com/stage...202v2
ECS Stage 3 kit - http://www.ecstuning.com/stage...e%203
PureMS Stage 1 kit - http://www.purems.com/products/product.php/II=810
PureMS Stage 2 kit - http://www.purems.com/products/product.php/II=1432
Brembo Gran Turismo - 328x28mm - http://www.purems.com/products/product.php/II=832
Brembo Gran Turismo - 332x32mm - http://www.purems.com/products/product.php/II=1103
Eurospec Sport Big Brake Kit, 330mm - http://www.eurospecsport.com/eurospecracebrake.htm
Eurospec Sport Big Brake Kit, 356mm - http://www.eurospecsport.com/racebrake.htm
ENGINE
Eurospec Sport performance blocks - 30V - http://www.eurospecsport.com/enginev6.htm
Eurospec Sport performance heads - 30V only - http://www.eurospecsport.com/cylheads.htm
PES Supercharger - 30V Only - http://www.pes-tuning.com/audi_a4_28v6.html 295+ HP & 260 TQ
IPP upgraded engine rebuild parts - http://www.importperformancepa....html
I will add links and parts to this list as I come upon them. If you have items that need to be added, or things that need to be removed, post in the thread and I will add it to this post as soon as possible.
Modified by robbyb413 at 6:17 PM 8/25/2008
Moderator
Discussion Starter #2
Re: The definitive b5 a4 2.8l performance mod thread (robbyb413)
Open for business guys. Help me out here, this is the extent of what I can think of right now. If you want me to add stuff, remove stuff, change a link, whatever just send it to me.
1 - 2 of 2 Posts
