1 - 20 of 670 Posts
well a friend of mine just bagged his 20th and after checking it out.. i was totally jealous.
so i decided to bag my rabbit over the winter.
going to piece it together as the $$$ comes in.
some pics of how it sit right now.
edit for updated pics.
Modified by MadTextureYo at 11:22 PM 3-5-2009
sick dude! another bagged vw in CT, and a mk1! http://****************.com/smile/emlove.gif http://****************.com/smile/emlove.gif
what i did was weld mk1 lower mounts on to the chapman strut, i know its a passat, but the mk1 mount is most similar to the syncro
and my rear goes pretty damn low, this is at about 20psi, the rear control arm sits on the pinch weld
Discussion Starter · #7 ·
Re: The Easter Bunny MK1 Build (Full Collapse)
after doing some research on the air forums i decided to only do 4 valves. Im basically just looking to go up and down no need to go side to. Its also the most cost efficient for my build.
So i went ahead and ordered the hot rod economy kit from AAC.
Besides what is included in the kit what else do i need besides a water trap as far as management?
heres the kits info.
3/8" 150 PSI Hot Rod Economy Front/Back Kit $499.99
3/8\" 150 PSI Hot Rod Economy Front/Back Kit
Click to enlarge
1x Viair 400c 150 PSI Compressor
1x 5 gallon tank
4x 300 PSI 3/8" Valves
1x 150 PSI Pressure Switch
2x 3 Prong Toggle Switchs
1x 40 Amp Relay
1x Viair Dual Needle 220 PSI lighted gauges
50 Feet x 3/8" SMC DOT Air Line
40 Feet x 1/8" SMC DOT Gauge line
Re: The Easter Bunny MK1 Build (MadTextureYo)
Quote, originally posted by MadTextureYo »
Click to enlarge
1x 5 gallon tank
1x 40 Amp Relay
i would get a tank gauge, and id use rocker switches
Discussion Starter · #10 ·
Re: The Easter Bunny MK1 Build (ruttness)
Quote, originally posted by ruttness »
yea i am not using those "toggle" type switches.
http://****************.com/smile/emthup.gif to AAC.
I ordered my air management yesterday morning and its going to be here today along with my rears.
fronts will be here 2marrow.
than ill start putting the kit together and have some fancy pics.
Re: (woody89)
Quote, originally posted by woody89 »
I'd suggest getting a fitting to drain air out of the tank if you need to. It makes things a lot simpler imo.
if you just want to drain air, then you can open the watertrap and let the air come out...if there is a significant amount of water in the tank, then a drain on it would be good to have
Discussion Starter · #15 ·
Re: (Ambrose Burnsides)
well 2day i got the air management and the rear bags.
2marrow the fronts come in as well as the fitting kit.
so hopefully 2marrow i will begin installing.
1 - 20 of 670 Posts
