ok, try road racing with this bad boy:
http://www.inil.com/users/dlbrown/ofhos.htm#HO 1984
These are a type of shifter made by Hurst. They're standard in the '83-'84 Hurst/Olds.
Basically, they're kind of a "His-n-hers" shifter. There are three shift rods in the center console. The left one goes P R N OD D and works like a normal gearshift with the exception of no L(ow). If you shift it all the way down into D, then the car is limited to third gear or lower.
When in D, you can shift the middle lever toward you to now limit the car to 2nd gear. When it's down you can pull the right lever to limit to first. When accelerating you can start with all the shifters toward you, then throw the right, center, then left one forward while accelerating. Kind of fun, but in reality they're not much more than a gimmick, since the tranny is set to shift at about 5200rpm on WOT.
This vehicle uses a three lever floor mounted shifter, "Lightning Rods". The left hand lever controls Park, Reverse, Neutral, Overdrive, and Drive detents. Placing the lever in the Overdrive detent will allow the transmission to shift from first through overdrive.
The center lever is used to "lock-in" second gear, and the right hand lever is used to "lock-in" first gear. To use the "lock-in" feature for first and second gear the left hand lever must be placed in the drive detent.
To "lock-in" second gear, push the button on the center lever down and pull the lever back. Next, to "lock-in" first gear, push the button on the right hand lever down an pull the lever back. When the first and second gear "lock-in" levers are used, it is necessary to manually upshift the transmission. This is done by moving the right hand (first gear) and center (second gear) levers forward respectively.
To manually downshift the transmission from drive to second gear, push the button the center lever down and pull back. To manually downshift to first gear, downshift the second, then push the button on the right hand lever down and pull lever back.
i've read it, re-read it, and i
think i know why it never caught on
obin
