I am once again consolidating threads. Previous threads:
http://forums.vwvortex.com/showthread.php?6762260-Part-Out-2002-GTI-1-8T-(Long-Island-NY)
http://forums.vwvortex.com/showthread.php?4830540-GTI-1.8T-Garage-Sale-Long-Island-NY
http://forums.vwvortex.com/showthre...rt-Thread-(OEM-OEM-Porsche-Aftermarket)-LI-NY
All prices are negotiable, especially for locals and on larger items. I am going to add a bunch of parts each day this week, here is the first lot:
(from the right)
-1.8T power steering pump with pulley $25
-Power steering pressure switch (x2) $12 ea.
-Power steering lines (2 sets) and reservoirs (not shown) $20 ea.
-Power steering and accessory bracket $10
-Coolant overflow ball $15
-Continental accessory belt for 1.8T with A/C deleted, <2k miles $20
-Accessory belt tensioners (x2) $10 ea.
-1.8T 90A alternator $50
-Revision L push-down coil packs $6 ea, 4 for $20
-A/C firewall distribution block/switch $25
-02M slave cylinder line with bleeder $30
-02M starter $75
-Brake booster to intake manifold aluminum / rubber hose, <1k miles $30
-02J shift lever and side bracket sold
-02M main shift bracket (not shown) $30
-TT short shifter lever Sold
-Upper strut caps, spacers, and covers $10
-braided stainless master cylinder lines $10 ea.
-License plate holder $7
-Rear tow hook cover $6
-SAI pump bracket $free
-Steering rack mounts (x2) $free
-MK4 brake master cylinder and reservoir (not shown) $25
(from the top)
-Front brake dust shields. Pair of 11.3" in good shape sold. Pair of 12.3" with some rust sold
-OEM 02M axles with securing nuts $75 each, $120 for the pair
-OEM front sway bar $15
-GTI passenger side front spindle, hub and speed sensor $40
-GTI front brake calipers. 2 unpainted with 40k miles $65. 2 with 80k miles, painted with G2 gloss black and Tyrolsport's brake stiffening kit installed $140
-Goodridge stainless 4 line brake hose set $60
-OEM rear brake hoses $free
-GTI rear brake carrier $10
-Rear stub axles, assembled with bearings, speed sensors and dust shields. Wheel studs are removed now and not included. $100 for the pair
-Stock front sway end links with prothane bushings installed $15
-VF Engineering front sway end links SOLD
-Rear upper shock mounts $20 for the pair
-Hood strut SOLD
-Rear third brake light $10
-Front driver side indigo blue door handle with lock cylinder $15
-Gray non-sunroof dome light, hairline crack in the housing $20
-Visor lights and rear overhead lights $5 each
-Manual HVAC controls SOLD
-Black e-brake cover (keeping)
(from the right)
-02M starter $75
(from the top)
-Hood strut SOLD
