Status
Not open for further replies.
1 - 20 of 564 Posts
Banned
I started this thread because the MK4 wheel thread was very successful.
With the confusion as to what wheels WILL and WILL NOT the the MK5, this thread will help people figure out what wheels WILL fit and what sizes those wheels are.
OEM and aftermarket rims are welcome!
Here is the format to follow:
Year, Model, Engine of vehicle
Brand and Model of wheel
Size of wheel
Offset of wheel
Brand and Model of tire
Size of tire
Brand of suspension
Model of suspension
Any added notes about the suspension
List any issues that you are having with the setup.
Post a picture of the wheels and tires you are talking about mounted on the vehicle you are talking about.
NOTE - DO NOT POST STRAY COMMENTS IN THIS THREAD. THIS THREAD IS TO POST THE INFORMATION AS STATED IN THE EXAMPLE ABOVE. MODERATORS WILL DELETE ANY/ALL STRAY POSTS.
THANKS
THE LEARNING CORNER
Wheel Offset
Click here to learn about wheel offset
Click here for a wheel offset calculator
Modified by user name unknown at 7:12 PM 5-10-2006
Banned
Discussion Starter · #2 ·
2006 Jetta 2.5L
Rondell #26
18 x 8
ET - 35
Cooper Zeon 2XS
225/40-18
KW Suspension
V1
The coilovers are spun all the way down in the front. The rears have about 1/2 inch of thread left.
The front and rear tires rub when going over bumps between 10-15 MPH along with going over bumps at speeds higher than 75 MPH.
When there is one passenger in the front seat, tire hitting fender is more prominent.
One passenger in the rear is possible, but not recommended.
Modified by user name unknown at 10:40 AM 6-9-2006
Re: (user name unknown)
Good Thread http://****************.com/smile/emthup.gif
hows the Cooper tire? I never ride on them....
Banned
Discussion Starter · #4 ·
Re: (Vento 3)
Quote, originally posted by Vento 3 »
I ran Kumho Exsta Supra 712's on my MK4 and I really liked them.
When I went to buy rubber for my MK5 rims, I was going to get the Kumho's again.
The guy talked me into the Coopers because of the wear rating.
The Coopers will last much longer than the Kumho's.
The Coopers grip like no other!
'06 GLI 2.0T
Neuspeed RS10
19x8"
45 et
18.9 lbs.
Goodyear Eagle F1 GS-D3
235/35ZR19
Bilstein shocks/struts
Neuspeed Springs
No rubbing. I did Todeshandler's mod, but it really wasn't necessary.
Re: (SMG)
2007 GTI, 2.0T United Grey Pkg 2
H&R sport springs
Hartmann 19"RS6 rims 45mm offset
BFG KDW 235/35/19 tires
Turtles walk slowly, but get angry fast!
22 Frontier 16 A8 15 S8 88 16v Scirocco
sort of a noob question....
at what point of an off set will i start to rub on a stock ride hight?
what does the offset even meen?!?!
ive read that a 45 is the start of a safe fit...
PLEASE TEACH ME EVERYTHING!!!!!!
Re: The Official MK5 Wheel Thread (BLKonBLKMKVGTI)
2005 Golf 2.0TDI 6sp
MTM Bimoto 19x8.5" Wheels
Offset / ET 45
H&R 45mm Sport Springs
235/35/19 Continental Sport Contact 2 Tires
No issues in the rear, had to bend a small plastic clip back on the inside of the front fenders to stop minimal scraping noises...all good now
Modified by Mk3 Mayhem at 10:33 AM 5-11-2006
Re: (SMG)
Quote, originally posted by SMG »
'06 GLI 2.0T
Neuspeed RS10
19x8"
45 et
18.9 lbs.
235/35ZR19
Neuspeed Springs
I run the exact same setup as SMG.
Re: The Official MK5 Wheel Thread (user name unknown)
'06 GLI 2.0T
Neuspeed RS10
19x8"
45 et
18.9 lbs.
BFG
235/35ZR19
Neuspeed Springs
Minor rubbing front and rear but no damage to tires yet, mods planned.......
2006 Jetta GLI
RH AW Crosslines
19 x 8.5
ET - 50
Nitto NT-555
235/35/19
Neuspeed/Bilstein
No rubbing to speak of unless driving spiritedly with passengers/cargo.
Re: The Official MK5 Wheel Thread (shucky)
Quote, originally posted by shucky »
So why do some rub and some do not with same wheels, offset, springs?
If you read some of the posts, you'll see that the difference can be in the tires. One manufacturer can make a 235 tire that's almost as narrow as another manufacturer's 225, and vice-versa.
Re: The Official MK5 Wheel Thread (Mud_Shui_Ah)
'06 MKV GTI
HP EVO
18x8
ET38
Contisport Contact 2 Vmax
225/40/18
H&R Coilover Kit
Minor front rubbing over bumps, still tweeking the coilovers http://****************.com/smile/emthup.gif
Modified by g60ADAM at 1:03 PM 6-26-2006
Banned
Hillside Imports project GLI..
RS6 replicas
19x8
et. 45
Falken Azenis
245/35/19
Neuspeed Sports
Koni Yellows
-Factory suspension limiters and fender liner modification
-No rubbing issues at all
Re: The Official MK5 Wheel Thread (Mpower1)
06 GTI
19X8 BBS CH
ET 50
235/35/19 Kuhmo spt
H&R coilovers
Minor rubbing, had front fenders rolled and cut out some of the inner plastic liner, no problems now
Modified by sldrsvw at 12:42 PM 6-9-2006
1 - 20 of 564 Posts
Status
