There have been some threads regarding different suspensions for the MkV platform. This is going to be a comprehensive list of the most common anti-sway bars for the front and rear, as well as end links. Also, feel free to leave a picture of your vehicle with details on your suspension component.
If I am missing something, feel free to PM me and I will add it to this thread.
Please, refrain from quoting full images and videos. Image quotes tend to clutter a thread.
*Disclaimer*
- All listings below are for a 2008 Jetta. Please check what is needed for your vehicle before making any purchases.
- CLICK HERE for the sister thread, The Official MkV Golf/Jetta Aftermarket Lowering Spring/Coilover Guide.
- CLICK HERE for the sister thread, The Official MkV Golf/Jetta Aftermarket Intake Guide.
- CLICK HERE for the sister thread, The Official MkV Golf/Jetta Aftermarket Exhaust Guide.
- CLICK HERE for the sister thread, The Official MkV Golf/Jetta Aftermarket Engine/Transmission Mount Guide.
OEM Components
When installing an aftermarket sway bar, it isn't alway necessary to replace certain hardware, unless there is damage or is required by the manufacturer. Here is a list of OEM components:
- Front end link: 1K0-411-315-P, MSRP $65.00
- Front end link nut: N-015-081-6, MSRP $1.70
- Rear end link: 1K0-505-465-K, MSRP $58.00
- Rear end link nut: N-102-861-11, MSRP $1.30
- Rear end link bolt: WHT-000-226, MSRP $2.44
- Rear bar bracket: 1K0-511-439-E. MSRP $21.50
- Rear bar bushing (for 21.6mm bar only): 1K0-511-327-AS, MSRP $12.70
- Rear bar bushing (for 19mm bar only): 1K0-511-327-AQ, MSRP $12.70
- Rear bar bracket bolt: N-107-193-01, MSRP $1.74
Still trying to find part numbers to front sway bar components.
- OEM bars are hollow, whereas most aftermarket bars are solid. This is where most of the difference comes from.
- The R32 front and rear sway bars is specific to the R32 and will not fit a FWD MkV, and vice versa.
- When making adjustments, the hole closest to the end of the bar is the least stiffest (more body roll) setting.
OEM Dimensions
GLI/GTI 2.0T FSI/TSI: 23.6mm front | 21.6mm rear
Jetta/Golf/Rabbit 2.5/1.9TDI/2.0TDI: 21mm front | 19mm rear
R32 3.2: 22mm front | 21.6mm rear
Fronts (no R32)
- ECS Tuning non-adjustable 26mm
- Neuspeed non-adjustable 25mm
- H&R adjustable 26mm
- H&R adjustable 28mm
- Whiteline non-adjustable 22mm
- Whiteline adjustable 24mm
- APR adjustable 27mm
- VWR adjustable 26mm
- ST adjustable 1" (25.4mm)
- Hotchkis adjustable 27mm
Rears (no R32)
- ECS Tuning non-adjustable 23mm
- Neuspeed adjustable 25mm
- Neuspeed adjustable 28mm
- H&R adjustable 22mm
- H&R adjustable 24mm
- VWR adjustable 23mm
- ST adjustable 13/16" (20.6mm)
Fronts (R32)
Rears (R32)
- Whiteline adjustable 22mm
*Disclaimer*
OEM Components
OEM Dimensions
Fronts (no R32)
Rears (no R32)
Fronts (R32)
Rears (R32)
