Saw your pic and said to myself no one carries an LEM P2000 .40 by choice lol.nah just borrowing it![]()
Anyone that says they know what we're getting doesn't know. Blue over here.:wave::beer:i hear for a sig :what:
What is that? Stamping the parts with the same s/n for tracing?Q... they microstamp, yes?
How hard would it be to swap slides with someone from out of state? "accidental like"?
lol yeah wouldnt be my first choice but as for an issued sidearm i dont really think its that bad.Saw your pic and said to myself no one carries an LEM P2000 .40 by choice lol.
microstamping is stamping serialized information into the striker so that any brass left behind would be able to track down the gun used to fire it.What is that? Stamping the parts with the same s/n for tracing?
Stupidity, really.What is that? Stamping the parts with the same s/n for tracing?
usually just the frame, slide and barrel...(Not sure if Glock S/N all pieces or just the frame)
No one using a gun with microstamping will pick up his brass to grind/drill the primers. It would be more likely that they would run a file over the end of the firing pin to eliminate the microstamping if that is where it is put. If it is on the inside of the chamber, you could probably run some fine sandpaper in it to eliminate that. Or just pick up the brass and dispose of it elsewhere. But in reality, criminals aren't usually that savvy anyway.Stupidity, really.
Basically the striker has identifiable marks (s/n, code, whatev), so when it ignites the primer, the primer is stamped with the gun ID.
Which is all well and good, but a few problems.
1. We know about it. Therefore we can work around it- grind it, drill the primers after shooting, swap slides (Not sure if Glock S/N all pieces or just the frame), clean up the brass, etc.
2. Useless if firearm is sold, stolen, or whatever.
Yeah, its got a date code of '94.... the guy i got it off of bought it new...said he only fired it a few times, if that much, then in to his safe it went, and it shows. It's super clean, no wear on the finish. I'm probably just going to do the same with it since i picked up the tac-ops a few weeks ago... but i feel it was a good trade for my vp9.Nice 226... dude at work has one that's been sitting in his safe for like a decade. I need him to sell it to me. LOL
"4.1.10.7 Shall incorporate a beveled magazine well, with beveling on all inside edges at the entrance of the magazine well to aid in reloading. No more than 0.1” of standard magazine (not including floorplate) shall be visible on front and sides of firearm when fully seated in magwell.Read the SOW. Those plates were specifically requested.
This is what happens when you give a bunch of 'tards a survey and actually adhere to the results.Page 10 said:4.1.17.10 Magazine floor plate shall:
4.1.17.10.4 Toe of the magazine shall extend past the firearm grip to enable positive gripping and rapid manual extraction of the magazine if the magazine is locked in place as a result of a malfunction (e.g. double feed) or if the shooter wears gloves.
I've never understood a 9mm revolver. Curious what's the appeal?just picked up this little guy in 9mm.
