I think you are right, saw some drops on my parking spot when I was returning home from workShould probably check the power steering pressure sensor for leaks. That fluid aint cheap.
Delete it! I replaced the banjo bolt on my power steering pump from a car that doesn't have the pressure switch and I've had zero issues.I think you are right, saw some drops on my parking spot when I was returning home from work
I did the same, I'm still not sure what the pressure switch really does...Maybe a warning light when it's too low?Delete it! I replaced the banjo bolt on my power steering pump from a car that doesn't have the pressure switch and I've had zero issues.
Thank you, I should be able to search how to do this for peace of mindI did the same, I'm still not sure what the pressure switch really does...Maybe a warning light when it's too low?
I believe the one I used to replace it was from an early mk4. Shoot for 2000 and older, I know my 2001 Gti had the pressure switch. Hope that helps a bit.Thank you, I should be able to search how to do this for peace of mind
Appreciate youI believe the one I used to replace it was from an early mk4. Shoot for 2000 and older, I know my 2001 Gti had the pressure switch. Hope that helps a bit.
I'll try again in a bit, you may be on to something. The faults that came were in the Brake control unit, no faults were shown that were engine related. Also this is tuned with immobilizer defeat which may explain part of my issue, although I shouldn't have a running issue either way..Doesn't 01314 mean it's having trouble communicating to other control modules?
01314 - Ross-Tech Wiki
wiki.ross-tech.com
Try scanning your ABS controller and see if there's any codes.
When I first posted on this board you responded with “what, are you me or something?” .... according to this picture: YES. 😂Put on the chrome tipped window, trunk, and gas cover switches I got a while ago.
I really dig those rimsThey're on.
I need to adjust height. Rubbing in the rear.
The front passenger brake line was getting rubbed heavily, needs to be replaced asap.
Me too! Really think it flows well.I really dig those rims
Bet those things are so easy cleanMe too! Really think it flows well.
I hope so! Going to give them a nice clean after raising the rear.Bet those things are so easy clean
They remind me of classic American wheels for 60's Muscle Cars lolMe too! Really think it flows well.
