Re: Staggered wheels on a quattro (Vrdady)
True, it would always be safest to go with the same setup on all four corners.
However, this is what I did on my dads TT.
18x8’s in the front with 225/45
18x9’s in the rear with 245/40
This setup yields the following:
Front:
225(mm) / 25.4(mm/in) = 8.858” <--width
8.858” * .45 = 3.986” <--height
(Assuming ~30-40% deflection at tire/tarmac contact location.)
.65 * 3.986 = 2.591”
(18” / 2) + 2.591 =
11.591”
This is more or less your running radius of the front end.
Rear:
245(mm) / 25.4(mm/in) = 9.646” <--width
9.646” * .40 = 3.858” <--height
(Assuming ~30-35% deflection at tire/tarmac contact location.)
.675 * 3.858 = 2.604
(18” / 2) + 2.604 =
11.604”
This is more or less your running radius of the rear end.
The difference between the two would then effectively be about 0.013” or 13 thousands of an inch. This difference is so small (0.1%) that its effect is negligible. Under/over inflation can easily create differences of 0.500” which is 40 times bigger than the above calculated difference.
So, as long as it is done carefully/correctly it can be quite safe.
Modified by A4_For_Baby at 10:55 AM 12-11-2005
