1 - 20 of 210 Posts
Moderator
Spring is coming up... time to think about dropping car back to the ground(well, for those of us in the snowy northern part of the continent at least).
Thought it would be interesting to get a thread with a picture of people's cars and their stance. When it gets enough posts I will add it to the FAQ.
Please include the following:
1) Picture of your car
2) Brand of Coilover/suspension
3) Front measurement (top of arch to ground)
4) Rear measurement (top of arch to ground)
5) wheel and offset
6) tire and size
7) spacer brand/thickness
8) other info (fender rolling, replacement tie rod ends, etc)
If you have more than one setup to contribute list them as seperate entries in one post, and when you make changes rather than removing the old info append another picture and set of info so that we have we have your car with multiple stances.
Re: The Stance Thread (robbyb413)
Koni Coilovers
22.8 in the front
23.4 in the back
MKV Rabbit Steelies (offset not sure)
No Spacers ( in this picture)
195 65 15's all around
Custom Fenderliner cutting (car did it all by itself by turning
I'll update when the RS are on http://****************.com/smile/emthup.gif
Re: The Stance Thread (Love 4 Veedub)
H&R ultra lows
Im pretty sure im around alex measurments
Stock tires and wheels
no spacers
STaSIS Streetsports
25"
25.5"
5) wheel and offset
Oetty RZ 19x8.5 ET35
6) tire and size
Toyo T1S 235/35/19
None
8) other info (fender rolling)
Fenders rolled
Couple extra 'cause of the Irish in me, arrr!
1) 1999.5 Avant 1.8t Quattro
2) Neuspeed Springs w/Bilstein struts
3) 25.5 Front measurement (top of arch to ground)
4) 25.75 Rear measurement (top of arch to ground)
5) Oettinger RE 18x8 et35
6) 225/40-18
7) No Spacers
8) No modding
Will update when I get the fender measurements
Modified by kenncmiller at 1:39 AM 3-20-2008
VMAXX coilovers
Brock B1 8,5x17" ET13
22.5 in the front
22.6 in the back
205/40/17 Toyo Proxes T1-R
All four fenders rolled..
Modified by brunerune at 7:44 PM 3/20/2008
Brand of Coilover/suspension - FK silverline
Front measurement (top of arch to ground) - 24.3
Rear measurement (top of arch to ground) - 24.6
wheel and offset - Ronal Bolero Et43
tire and size - Goodyear Eagle F1 225/45/17
spacer brand/thickness - FK spacer front 15mm and noname rear 20mm
Modified by Soupie69uk at 11:19 AM 3-28-2009
fk silverline coilovers
23.2 front
23.2 rear
TSW Hockenheim R, 16x9, et 30
nexen 3000, 225/45/16
no spacers
slight rolling of front fenders.
Really bad Pictures. I'll update
KW INOX V1's
22.7 front
23.0 rear (1st picture is 23.6")
BBS RF 3piece
Front 17x8.5 et 20 205/45/17
Rear 17x9.5 et 18 215/45/17
Lug Wrench rolled fronts
No spacers
Never rubbing
<7,000 miles out of directional tires
Modified by 98a4 at 9:46 PM 4-15-2008
Re: (98a4)
2) H&R Coilovers
3) 24"
4) 24 3/4"
5) Ronal Alphards (Merc. SL500)
18x8.5(F) ET.35
18x9.5(R) ET.40
6) BFG KDW2's
215/40 (F)
235/35 (R)
7) H&R 20mm Rear spacers. Final offset in rear is ET. 20.
8) Stock Fenders.
Re: (Gti.1love.1life)
temporary stance
KONI coils
24 inches up front
24.8 in the rear
Keskin KT2s
18x8.5 et 45? (not really sure on this set) all around
225/35/18s all around
H&R 5x112-5x130 22mm adapters
fenders rolled and liners cut out
Re: (kish0000)
Really crappy photo, I need to go out and take more...
H&R Coilovers
24" Front
24.5" Rear
OEM Sport Wheels
Falken FK452 205/55/16
No spacers (but need some)
Re: (sixfiveoh)
5) wheel and offset
6) tire and size
1) ok here
2)K-Sport coilovers
3)24"
4)23.5"
5) 18x8.5 rs4 wheels by Velocity (not sure on offset)
6)225/40/18
7)none used
8)rolled fenders
NOTE: The measurements are after lowered more then the picture shows.
Modified by iwearpro at 12:24 PM 4-18-2008
Koni Coilovers
24" in the front
25" in the rear
07 Passat 16x7" Steelies +38 offset
Jetta Dub-caps
4mm Spacers in rear
205/55/16 all around
Front fenders are partially rolled
Upper Shock tower was clearanced/bubbled for arm movement
1) 2001/08 Avant 1.9TDI
2) KW Sport-Kit
3) 25.5 Front
4) 25.75 Rear
5) Audi RS6 8x18 ET35
6) Yokohama Parada 225/40-18
7) No Spacers
8) No exterior mods
5) Audi S4 (B6) 8x18 ET35
Modified by Dianick at 1:15 AM 10/8/2008
H&R Race springs on RS4 shocks
Front and rear 24"/61mm from the ground to the arches
Wheels: BBS RC 18"x8.5 ET30
Tyres Nankang 255x35x18
H&R 5mm spacers
RS4 arches front & Rear
Re: (docurley)
5) wheel and offset
6) tire and size
1. BANG
2. H&R Coilovers
3.n/a
4.n/a
5. 18x8 et37
6.Yokohama S-drive 205-40-18
7.n/a
8.n/a
Modified by BLK1.8Turbo at 7:54 PM 5-6-2008
Modified by BLK1.8Turbo at 8:25 PM 5-6-2008
Re: (BLK1.8Turbo)
vmaxx coilovers
a little under 22.25"
22.5"
2007 mercedes e320 wheels 16x8 et36
205/45/16 blue streak stiletto's made by bridgestone
10mm spacers up front/20mm in rear
front et26 rear et16
Modified by sum1namedjames at 10:03 PM 4-10-2009
Modified by sum1namedjames at 1:07 AM 6/2/2009
Modified by sum1namedjames at 1:09 AM 6/2/2009
1 - 20 of 210 Posts
