The T0oDamnFast Stock Valence Mod
here is the how to:
anybody tempted to do this, i would seriosly only recommend doing it if you are installing your own exhaust. first and formost, drive to pep boys but some jack stands and jack your car's ass up. there is one bolt that suspends the muffler/tips hanging down at the rear of the car, if you already have your exhaust installed, unbolt that, if you dont, install everything but that last bolt and let the tips hang. take a magic marker (washable) and mark off where the exhaust alligns as you raise the tips against your stock valence, mark off a little bit and start cutting... do not cut everything all at once, this is not a 1-2-3 job, it takes patients if you want it to come out like mine... Continue to mark off more and more until you your exhuast sits snugly and the bolt the holds the tips comfortably bolts in. at this point your saying to yourself, "i must have had too much
have a
[Modified by T0oDamnFast, 3:13 PM 12-15-2002]
