Well, I had another VW adventure last night. Sorry, no photos this time. It was dark and raining, so I'll just have to describe it for you.
It was a dark and stormy night, I was driving home from work. Well, it was raining and starting to get dark.
Windshield wipers were working smooth and strong. I even thought to myself that they seemed at least as quick as ever. I was back and forth between the intermittent and low settings as it wasn't a hard rain, more of a semi steady sprinkle.
About ten miles from home I noticed that the wipers were slowing down on the return stroke. I also noticed that the wipers were doing a more than adequate job to the point of making some squeaking noises against the glass.
I thought "Wow, maybe the contact against the glass is so strong that it's actually slowing the wiper motor?" So, I turned them down to the intermittent setting. The slow return continued, but not for long. I was thinking: "There's certainly some resistance. Maybe the linkage needs regreased. Hope it doesn't over tax the motor and blow a fuse."
It was about that time that the wipers quit on the down stroke, right about in the middle of the windshield.
I realized that the water was beading up pretty well and I could still see well enough to drive, so I decided to continue on home before addressing the problem. I was pretty well convinced that I would find a blown fuse.
I figured that I could at least get the wipers to reset to park with a new fuse, but unless I figured out what went wrong with the linkage (if that's what it was) I probably wouldn't have reliable wipers the next morning, but maybe the rain would be over by then.
Got home. Pulled the fuse. It looked to be intact. I swapped it out anyway. Still no wipers.
So I popped the hood and pulled the fan cover. (Oh, I need to clean under here. There are pine needles and leaves from before I added the leaf guard in the hood.) I started trying to work the linkage off of the rotary arm of the wiper motor. That's when I saw it...
One of the three bolts that secures the motor to the mounting bracket had rattled itself loose and then backed out and up until it made contact with the rotary arm and jammed it.
Got out the 10mm open end wrench and turned the bolt back in. Probably should have taken it out and added some thread locker, but it was dark, raining and cold beer by the warm hearth was beckoning. Anyway, it still had the wave washer and I made sure it was good and tight this time.
I went back in the cab and hit the switch hoping that the motor hadn't burned itself up trying to get past the obstruction. To my joy, the motor jumped to life and parked.
I went inside to meet my well deserved beer with a smile on my face and a story to tell. That, my friends is why I love my Rabbit.
