After bleeding more air out of the lines; the Turbo Diesel has been revived.
Holy crap! It started and runs well enough to drive. Jump in, let's go! Probably the worst driving conditions in months. The snow is heavy and turning to rain which is melting the ice layer underneath. It's been relatively easy driving on ice and light snow recently, which has made me a bit complacent, so off we go with minimal tools. No umbrella, no snow shovel and I haven't plowed yet because...I'm playing with my VWs again!😀
Looks like clean snow to me. 👍
Made it down to the highway and into town for a mail stop and a first adjustment by the tuner.
All gauges are functional and showing good numbers. Of course we've only driven down hill about three miles and haven't been past third gear yet. We have heard a bit of that sweet turbo whine and seen a couple of PSI on the boost gauge when I goosed it. OK, let's take it up to the pass.
We saw more good mild numbers on the hill climb. Boost up to 6 PSI at just over 3000 in third gear. Highest EGT reading at 800F on the climb. Oil temperature never got above 225F.
After another adjustment at the pass, headed North along the lake shore looking for a straight-away to try out fifth gear. Hopefully in a spot without much standing slush on the highway. Found one, although conditions were still slushy, so not ideal for high speeds.
Hard to compare apples to oranges due to the egregious driving conditions and the added weight of a 200lb VW mechanic in the jump seat, but so far I am thrilled with how smooth and responsive the little TD is. As far as power, at this point it seems to be lacking in horses in the high gears compared to the 1.9D. Still lots of room for tuning before the exhaust upgrade and the intercooler...
So, after a very successful maiden voyage, we headed back up the mountain.
I could crawl up this hill in first with the studs on ice and light snow, but 2" of wet snow on top of a melting ice sheet? Well that's a bit much to ask of most 4WD trucks of this stature, let alone a lowly Rabbit, even if 'Fwd is the better half of 4wd' as I like to say. No LSD either, just another good old early FN 020.
So, after a first low speed failure, I tried to power and spin my way up the notorious 'first hill' of our unplowed driveway at the junction with the County road at the terminus of their plow route.
No dice, but an opportunity to give her the onions. A red line a day, right? Fast says he saw the tach max out briefly.
We're walking about a mile to get the plow. It's freezing rain. No umbrella. If we had brought a shovel we possibly could have scooped the tracks and made a runway, but we don't, so we parked the Caddy. First shut off after 26 miles logged.
Two hours later.
2nd start was like butter. I rescind my earlier comment about not starting as easily as the 1.9L.
OK. Let's try that hill again after a little grooming by the Duetz.
Made it home and back in the tent for the tuner to make the next round of adjustments which are now complete, awaiting the next test drive.
🙄 Might wait for better weather though.
