To recap for those that may be lost in the weeds, the symptom being diagnosed and treated is/was an oil drip in the parking lot coming from the area of the turbo.
Wetness on the oil return line connection was noticed some time ago and the one accessible bolt was tightened. The gasket was a used cardboard gasket, possibly original equipment.
The drip may have been from CCV putting oil in the intake tube or from the oil return connection or both.
At the time that the drip was noticed, the truck was noted to be overfull on oil.
Steps taken:
*Oil return line gasket replaced and flex hose replaced to ensure no restrictions.
*1/2 quart of oil drained from the crankcase. Now shows at the full line.
*dielectric grease added to the intake to turbo connection as a sealant.
There have been no performance issues with this engine. It has just over 1K miles since the rebuild. Starts easily and holds it's own against a 1.9mTDI climbing hills in 5th gear.
Looking forward to trying out the 20psi tune but it was already fast and powerful. Of course that will be after we get a functional hood release going and maybe after the snow melts off.
Big thanks to @fastinradford for getting s**t done! I could have dragged this out for a month or more if left to my own devices. 😎
Plastic cam splash guard is being utilized in the G60 cover. Otherwise the valve cover switch did end up making the PCV system much shorter, probably with less opportunity to drain back into the case.Not certain what the diesels have but if you do not have the cam cover, I would get one.
Steps taken:
