Re: Thermostat - how cold can you go? (VWhombre)
I pesonally run an 80 degree celcius t-stat. Anything much colder is designed for extreme environments. If you run too cold of a thermostat your fuel mileage will suffer because the car takes longer to warm up, and can drop too much on the highway. Furthermore, much colder of a t-stat and your oil will stay too cold, which won't allow any moisture that has found its way into the system to boil off.
