Just got the parts to do this, and wondering how much time I should budget....
It looks like the thermostat is in a small housing that bolts onto the water pump housing.
Can you access this from the bottom of the car without removing anything (ie P/S pump)?
Just remove hoses and good to go?
2nd question, if I'm draining the coolant I might as well do the water pump too, obviously I'd have to disconnect the tensioner, same questions is anything in the way of dropping it out the bottom of the car? Any other gotchas?
Thanks!
Skye
Thanks!
Skye
