1 - 7 of 7 Posts
I got this message when making a small change to the central electronics module. However, I have made changes to this module before, and therefore didn't want to go ahead and have it replace the values. Also, in my scan, it appears that these fields are NOT uninitialized, as they do have values!
Why am I getting this warning? I didn't have it before when I made changes to this control module, so why am I getting it now?
I have disconnected the battery recently for a steering wheel install, could this be related?
This is probably the first time I've made changes to this controller since upgrading to VCDS version 11.11.1 . Could that have anything to do with it?
Posted below is my Autoscan.
The error in the Engine module is likely from the battery disconnecting, I'm going to erase that one and just see if it comes back. I'm also going to erase the sound system code, since it hasn't happened in 2 months, and see if it comes back also.
Thanks in advance for all your help!
VCDS Version: Release 11.11.1 (x64)
Data version: 20111209
Friday,24,February,2012,10:33:52:17460
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUHF78P17A078249 Mileage: 108470km/67400miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 P HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH14--- Serial number: AUX7Z0F8FNF0NY
Coding: 0103010A1C070160
Shop #: WSC 93168 999 92090
VCID: 3FA3930B6E669C1
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0001
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1163
Revision: 04507000 Serial number: 00000608140867
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 14096CA73760AF9
No fault code found.
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H13001
Coding: 0037506
VCID: 68F168575B68FB9
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
Component: KlimavollautomatH18 0300
Revision: 381573 Serial number: 8P0820043M
VCID: 364DF62F415C5D9
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006221826
Coding: A18C4FA18014100000181800180000000039EE175C1100
Shop #: WSC 06314 000 08192
VCID: 40A190F71398E39
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 11
Reset counter: 251
Mileage: 105763 km
Time Indication: 0
Date: 2012.01.19
Time: 09:30:00
Freeze Frame:
OFF
Voltage: 12.70 V
OFF
OFF
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 A HW: 8P0 959 655 A
Component: Airbag 9.41 H12 3890
Revision: 91H12389 Serial number: 0035W0G027P4
Coding: 0030605
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0012142
VCID: 41A795F31892EA1
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 931 B HW: 8P0 920 931 B
Component: KOMBIINSTR. VDO H19 0570
Revision: D0H19003 Serial number: 2248F003006694
Coding: 0000008
Shop #: WSC 94753 999 11310
VCID: 3245CA3FAD34419
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 J HW: 1K0 907 951
Component: J533__Gateway H12 0160
Revision: H12 Serial number: 320010682386BA
Coding: 3F3F034207002102
VCID: 2E7DDE4FB90C659
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H19003 Serial number: AUX7Z0F8FNF0NY
Shop #: WSC 94708 999 82916
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0001209
1 Fault Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3449CC2757204F9
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 D
Component: 02 KSG H04 0050
Coding: 9BC003182D28850FC88F047300
VCID: 3D5FE903646A8E1
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674696686537
Shop #: WSC 00000 000 00000
VCID: F1C78533E8B2BA1
1 Fault Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 10
Reset counter: 231
Mileage: 105555 km
Time Indication: 0
Date: 2011.12.24
Time: 08:55:24
Freeze Frame:
Temperature: -9.0°C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0001209
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 K HW: 8P0 035 186 K
Component: concert II US H52 0470
Revision: 05S Serial number: AUZ5Z6F6032338
Coding: 0001005
Shop #: WSC 65286 005 00000
VCID: 3A55E21F7544B99
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0001176
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0001176
End ---------------------------------------------------------------------
Vendor
You're getting that message because the Importer Number in that module is '000', which would be unacceptable (or "uninitialized") to *some* modules.
11.11 does indeed produce a warning for this, because it got real old explaining why various modules were rejecting codings when one or more of those fields (WSC, Importer Number, or Equipment Number) were left with nothing but 0's in them. You should have 3 choices at that point:
[Yes] to put in some default values
[No] to leave everything as is
[Cancel] to manually edit the values
Since you know for a fact that this module doesn't object to the 000 in the Importer Number field, you can click [No] and VCDS will try to make the coding change with the existing WSC/Importer/Equipment combination/
-Uwe-
1 - 7 of 7 Posts
