1 - 4 of 4 Posts
So I was normally driving today and all of a sudden an EPC light came on, completely lost boost and pulled over. I read the code and it said p2138 correlation malfunction d/e voltage
So I assumed my sensors are both out.
the only weird part I’m seeing is that I’ll be able to pull full boost and drive at least 30 minutes but then the light puts it back in limp mode. So it’s not happening all the time
What should I do
Replace the throttle body connector pins with the ones they should've used.
Can't believe there's not a recall for this screw up on their part.
Check out this thread for part numbers and procedure:
1 - 4 of 4 Posts
