1 - 7 of 7 Posts
Hey everyone, I have had a CEL on for a little bit now, and I just had it read and it seems to be a misfire. The car has felt a little bit sluggish lately, but I was thinking it was because of the Arizona heat.
What I am thinking is if I go with a colder plug, because I am reflashed, that the code should go away. Any input?
Re: Throwing a misfire code. (EasyTarget)
Quote, originally posted by EasyTarget »
clear the code and if it happens again get it checked out. i had a misfire in cyl 3 awhile ago, but it was a random occurrence and havnt had another one.
· Vendor
Re: (EasyTarget)
I cleared the code and it came back a few hours later. I also plan on replacing the plugs for some coolder ones no matter what the problem is.
Is the misfire in the same cylindar each time?
If so, try the following and see if the misfire follows the change:
Swap your coil packs - test
Swap your spark plugs - test
Swap your injectors - test
If its still misfiring at this point, and if you still have a warranty, I'd take it to the dealer.
1 - 7 of 7 Posts
