1 - 20 of 37 Posts
I have a mk4 gti with verdict motorsports and 42 dd bushings. I would still like to tighten up the slop in the knob. I feel my next step would be to upgrade the spring that lets you drop into reverse. I think this is the culprit to the slop. So my question is has anyone tried to upgrade this spring? Any comments or advice would be cool.
Update edit:
It was brought to my attention that this slop is due to the following bushing. Info came from another post
This was stumbled upon by another Vortexer in upgrading their endlink bushings. This OEM piece is a significant increase in design and feel over the original bearing. As you can see here, the original part has a multitude of air gaps and has a slightly softer plastic, though the feel of the plastic may just be due to wear over time.
The new part (part # 1K0 711 699) has all of the additional air gaps filled in addition to being firmer material overall.
I thought about using some of the OEM goop lying around the shifter when reinstalling, but it appeared it was greatly contaminated with a multitude of crap. I opted for the dielectric grease I had on hand.
I will give this a solid 25% over stock, possibly even 30%. Even BEFORE installing motor mounts or dogbone bushings, the "flop" of the shifter when on and off the throttle in 6th gear has completely disappeared. Shifting is completely firm yet smooth with very marginal, virtually non existent shaft play while in gear.
Having the same issue. But I dont believe its the spring. Im thinking its the plastic bushing in the shifter base. Have not been able to find any where that sells just that with out the whole shifter assembly.
Discussion Starter · #9 ·
2009 A8L W12; 2000 Jetta VR6; 1982 Caddy 2.0T
Discussion Starter · #16 ·
Thanks for the heads up!!!! This is the last step for my shifter. Did you get those motor mounts installed yet filthwagen?
got the dogbone in, doing the mounts this weekend did yours come not assembled straight (a few degrees turned)?
Anyone install it yet?
I did yesterday. Cleaned up a lot of the slop. Wish I would have done it a long time ago. I have the solid mount bushings on order.
1 - 20 of 37 Posts
