Re: (arenjenkins)
Quote, originally posted by arenjenkins » |
and when you say vibration dampner bolt, you mean the 4 with 6mm allen heads right? your not trying to take the center bolt out correct? |
Once you get those four allen bolts out of the pulley sitting on one end of the crank back passenger side of motor, the one that connects to water pump pulley and coolant pump pulley, it says to remove the vibration damper which is held on by that bolt in the middle and runs the alt. belt, right?.....so I guess I was trying to get that off,
....and im guessing I wasnt suppose to (never got it off though)...but I swear thats what the bentley said to do to remove the lower timing belt.
But i didnt even need to time it, everything was timed, but I think I didnt get the cam gear into that notch on the end of the cam right...that little half circle notch thing got pushed out when I put the gear back on after head swap....it was a matter of time before it slid loose I guess, still not sure what exactly happened. But that would also explain why my belt was about to fall off on the INSIDE of the cam gear. Dont care anymore because after I fixed that and it started, then slapped my coils on that came last week http://****************.com/smile/emthup.gif
but thanks for the help...and to clear things up am I not suppose to remove the center bolt to get that damper off? I know theres a bolt to the crank? down there I dont want to remove, but I thought it was behind the damper.
Modified by 253jetta at 7:47 PM 3-21-2010
Modified by 253jetta at 7:48 PM 3-21-2010
