1 - 5 of 5 Posts
I'm replacing the timing belt on my 2001 A4 1.8t. The original engine dropped 2 valves so the AWM engine has been replaced with an AMB block with AEB head. According to the directions included with the timing belt kit (from blauparts) and also according to autodata, there is to be a 6-10mm gap between the top of the tensioner piston and the bottom of the tensioner pullley bracket. If that is correct, (which doesn't make sense
) The piston on the tensioner does not make contact with the pulley, therefore the hydraulic tensioner is doing nothing. I believe this is simply a mistake, and there is supposed to be 6-10mm of the shaft expposed. Can anyone confirm this?
Re: Timing belt question...and yes I searched (The*Fall*Guy)
I'm repacing the T belt on a 99 passat. Bently shows tensioner pulley totally different than mine. and talks about tensioning. It looks like I should just pull the pin and thats it. Any help would be great.
Discussion Starter · #4 ·
What's the difference in the tensioners? got pics? thanks
Re: Timing belt question...and yes I searched (Dubluva)
Quote, originally posted by Dubluva »
Old Tensioner
New Tensioner
Pictures jacked from here
1 - 5 of 5 Posts
