Well, I have access to a timing light now, so I've decided to take on a new project... timing my engine. I know, may sound like no big deal, but I want to make sure it's 100% correct... so I thought I'd ask the pros.
First off, I know where to check the timing on these cars, so I don't need that info. I also know how to loosen the distributor, so that's no problem either. http://****************.com/smile/emthup.gif
What I do need to know is this:
I've had my Shadetree mechanic set the timing, and all he did was adjust the idle speed, everything connceted.
I've been reading the Bentley, and they recommend to set the timing with the coolant temp sensor unplugged, and the idle at 2000-2500 (after proper engine warm-up has occurred). First off, I can't get the engine to stay at a constant RPM (other than idle), and I can't see the timing mark until I do this. If I can adjust the idle safely at idle, I can do this... but do I leave the temp sensor out? If I adjust it this way, then connect the sensor the timing mark is a little off, but the engine seems to run great...
Anyways, I want to hear what you guys have done. I have no mods, so there's nothing external to factor in.
Thanks in advance
JASON
Thanks in advance
JASON
