I was able to grab another cabby last july and start the process all over again... (I had a 1989 that I ran for 5-6 years and eventually sold)
I have been keeping track of everything in notes on my phone.. time to dump the data here and let you all in enjoy. I will try to get the photos uploaded and placed in the text.
1985 cabriolet expenditures
Car $500.00
Oil pan gasket $6.15
Valve cover gasket $14.95
Fuel pump relay $free
Accessory belt $6.32
Windshield seal $50.00
Seat guides $3.68
Heat paint vcd $6.99
Paint & Supplies $50
Trim clips $15
Borbet type E wheels $150
Rotor $6
Distributor cap $14
Fuel filter $14
Rear reflector $28
Heater switch $6
New top $270
Headliner $170
Windshield $50
Fabric for pad $17.00
Alternator $89
Vac tubing $4
Oil filter $0
Oil $0
Air filter $32.99
Steering belt $8
Dipstick funnel $7
Top bracket $35
Duckbill $40
Top strut $38
Top seal supplies $19
Top tensioner $63
Battery $140
Tape deck $0
Hot pulse relay $12
Clamp collar $2
Cutting compound $25
Reman starter $75
Bumper end caps $65
Ignition switch $11
Lower ball joint $27
Labor (for ball joint/exhaust)$110
Power steering parts $40
Ps line/fluid $35
Ps install parts $10
Battery hold down $6
Trans to chassi ground cable $7
Hazard switch $10
Bumper hardware $50
Install parts for Bumper $25
Valve stem caps $9
Bulbs for vdo $11
Usb/ power port $12
Install parts $19
Rokkor Coilovers $260
Exhaust Connector and Clamps $17
New tires $244
Junk yard finds $60
Passenger hub $30
Passenger wheel bearing, install and alignment $292
Ball joint $22
Door strikers $9
Center caps $25
Stereo $65
Speakers/wire $60
Purchase date: july 6th 2019
Cleaned interior: July 6th
Discovered a friends name written in the manual
Valve cover gasket: 7/24/19
Also Painted valve cover
Removed windshield 7/26/19
-discovered small rust hole on lower passenger channel.
Fixed with “lab metal”
Broke windshield trying seat new seal
Painted : 7-28-19
Rustoleum gloss black dtm
8/1/19
Three days of 1.5-2.5hrs of wet sanding. Up to 600 grit
Fresh washing after last wet sand
8/6/19 1000g and 2000g and an impatient scratch remover and polish on a spot to see how shiny it would be
8/8/19 Purchased Borbet type E wheels
https://i.ibb.co/kJSGP8b/77-C9-BDCA-7-FD9-4-A54-801-A-C12524514000.jpg
8/10
Seat bolsters. Found free office chair with close enough colored fabric
[img]https://i.ibb.co/0VsFW9L/7-B5-C79-F1-AEE1-4250-B855-F77-BCCF50-A09.jpg
8/13/19
Removed carpet to degrease and clean it.
Discovered small hole in floor. Will patch with lab metal.
While waiting for lab metal to return from lending it out i decided to paint the floor with rustoleum
Before:
After:
8/14/19
Filled spot with lab metal top and bottom, sprayed some of bottom with rubber coating.
Installed clean carpet
Patched passenger seat to cover weird melted plastic stain from who knows what...
8/17/18
Repaired and replaced grounds
8/18/19
Replaced cap, rotor and fuel filter
Also did more wet sanding
8/20/19
Windshield installed. Also noticed wiper arm on driver side was stripped. Added a washer under the nut to give it more clamping force. Seemed to work.
8/29/19
Off with the old top. replacing headliner and fixing top pad. Bought burlap and underlining matierial to cover top pad.
Also replaced heater switch... still no fan, will try relay or new blower
8/30/19 Headliner finished.
8/31
Put on oil pan gasket. Omg worst time getting things lined up. Eventually used a floor jack to hold pan in place. Removed alternator, bought new mounting bolts. New power steering belt, installed alternator belt. Replaced vac line connection tubes, replaced air filter and did an oil change.
When reinstalling the power steering pump i noticed half the bracket was missing and the power steering line will need to be replaced very soon.
8/3/19
Installed new alternator.
Installed 3d printed charm from cuz bruce
9/6/19 installed new dipstick funnel
9/7/19 top installed, rear window put back in place. Waiting to finish right rear of top for lift support to arrive from ebay seller.
9/10/19
Installed lift struts for top
9/12/19
Tightened top near rear seals, tightened front of top to lay flat.
Another two coats of paint. Painted until dark.
9/13/19
Another wet sanding
9/15/19
Repaired switch on heater fan. I think it was just plugged in in an
incorrect orientation.
Also installed chin spoiler
9/15/19
Registered ordered antique plates “mk1”
9/16/19
New battery installed. Car starts
9/17
Put strips back on with new clips.
Also on 9/17
Tape deck installed. Free from “Dover Bill” brand new in box saved since 1992 in his garage
9/24/19
Installed clamp collar to retin steering wheel bearing
9/29
Starter died.
New plates arrived
Worked on wet sanding and buffing hood.
10/3/19
Test fit custom bumpers. Had customer weld aluminum half strut to 1-1/2 aluminum tube stock removed oem bumpers. Drill and installed brackets and trim
Rear bumper is perfect. I need to figure out how to get the front bumper tighter to the car
10/6
More wet sanding, tried hand waxing
10/11/19
Installed bumper endcaps, painted bumber and installed retainers and screws to hold everything together. Still want to bring the front bumper in a bit.
10/24/19
Car came back from shop. Installed a new ground from battery to transmission. They removed ground from chassis to battery. Need to add that. Starter was installed. Starts right up now.
Powersteering has been squealing. Looked to see bracket is broken and missing all tensioner parts.
Updated shots
11/4 bought power steering line and fluid. New pump and tensioner parts arrived a couple days ago. Hopefully will get everything transfered over this week.
11/05
Added ground wire from tranny to chassis. Also added battery hold down kit
11/7/19
Friend helped me out with lift at his work to install the pump and he nh-oiled the whole underside.
Pump has all new bolts, hoses and fluid.
Notes-
-spare tire well has a small rust spot.
-Heat shield had been screwed directly into the fuel tank.
-small fuel spot on fuel tank wet. Maybe replace fuel tank next season
12/24 dropped off cabby at granite state glass because the windshield was leaking at both lower corners. They seemed to have fixed the issue by sealing the corners with a black sealant of some sort. Hopefully it does the trick. Not looking to ruin any more relays with water dripping on the fuse box.
1/26 weekend
Car stalled out the other day 1/4 mile from the house. Brought battery and alternator to advance auto to have it checked. After a couple trips it was discovered the alternator wasnt giving out a charge. Went to autozone to order a warranty replacement
2/23/20
Took the dash apart and installed t new voltage regulator on the cluster. Seemed to be working fine... then as the car sat it dropped out again. Restarted the car and it was working. Hopefully it stays working.
2-23-20
Finally replaced bulbs in vdo gauges. Also installed a usb/cig lighter jack with a lighted switch I didn’t want to add anything too modern, but I do want to be able to charge my phone if I am going on a longer trip in case I have to call for a tow.
Also new problem...oil buzzer keeps going off. Need to make sure i didnt forget to plug something in. Going to try flipping the voltage stabilzer as it seems maybe i didnt need to flip it.
2/25/20 flipped stabilzer. Problem solved. Noticed bar gauge light wasnt working need to check wiring or bulb
2/26/20 found an old socket for the peanut bulb when installing my usb port and wired another light to plug into my heater faceplate. Also fixed the bar gauge bulb too. (It just unplugged)
Car $500.00
Seat guides $3.68
Trim clips $15
Rotor $6
Distributor cap $14
Fuel filter $14
Rear reflector $28
Heater switch $6
New top $270
Headliner $170
Windshield $50
Alternator $89
Vac tubing $4
Oil filter $0
Oil $0
Air filter $32.99
Steering belt $8
Dipstick funnel $7
Top bracket $35
Duckbill $40
Top strut $38
Top tensioner $63
Battery $140
Tape deck $0
Hot pulse relay $12
Clamp collar $2
Reman starter $75
Bumper end caps $65
Ignition switch $11
Ps line/fluid $35
Hazard switch $10
Bumper hardware $50
Valve stem caps $9
Bulbs for vdo $11
Usb/ power port $12
Install parts $19
New tires $244
Junk yard finds $60
Passenger hub $30
Ball joint $22
Door strikers $9
Center caps $25
Stereo $65
Speakers/wire $60
Painted : 7-28-19
8/1/19
8/10
8/13/19
Before:
After:
8/14/19
8/17/18
8/18/19
8/20/19
8/29/19
8/31
8/3/19
9/10/19
9/12/19
9/13/19
Another wet sanding
9/15/19
9/15/19
9/16/19
9/17
Also on 9/17
9/24/19
9/29
Starter died.
New plates arrived
10/3/19
10/6
10/11/19
10/24/19
Updated shots
11/05
11/7/19
Notes-
1/26 weekend
2/23/20
2-23-20
