1 - 4 of 4 Posts
i am buying rims that have a 225/45 17 on front and a 235/45 17 on back?
will this screw up my quattro...??? its only like 1/3 of an inch difference
whch would beabout the same a putting on two new tires withtwo older tires?
but will this screw up my quattro? or abs?
Re: tire sizes on quattro.. (vw.insect)
shouldn't...but I look at it this way..as long as the rotational circumference is the same you shouldn't have a problem
btw you still want that fog? and grills
Re: tire sizes on quattro.. (blacka4)
i do but i cant afford it right now.. car is getting a new timing belt because they didnt do the water pump with it last time. and now the water pump went bad. so i am going to be out 1200 buck there.. and it needs four tires so i am just buying rims and tires.. otherwise i would. if you still have them cloaser to spring i will take them then..just got to catch up.
ouch that sucks..I need to do my tbelt soon...yea catching up...I know what you mean
I hate not being able to aford my nav+ upgrade that I want to do
1 - 4 of 4 Posts
