To port or not to port that is the question??
477 Views 2 Replies 3 Participants Last post by  A1Rocco
2
I have alot done to my 1.8l 8v motor and i'm thinking of porting the head is it worth it, Or should I just hold off 'till the 16v engine I'm building is done. Talk to me people is it worth the trouble???
Am I looking at really small gains?
Hit me back!
See less See more
1 - 3 of 3 Posts
Re: To port or not to port that is the question?? (Wickeddub)
I once read that for every 1 cfm, you can gain 1.1hp. If you do the math,on a PF engine code you can gain approx. 15% on the intake side and approx. 20% on the exhaust.
I'm in the process of porting my PF head. I have access to a flow bench so I will try to get as many numbers as I can. Stay tuned!!
I went through the process of pricing out bigger valves, but the cost vs. hp gains was ruled out.
My theroy is Port em' if ya got em'!!
Hope this helps.
See less See more
Re: To port or not to port that is the question?? (German Engineered)
In my 1987 copy of Greg Raven's book it has a chart on page 52 that says 1cfm = 1.45hp. Hmmm. I think oversized valves are hard to justify expense wise but if you have a well done up 2.0L and a big cam they will make a big differnce. You need to have a well ported head and a cam like a Schrick 280 that peaks at like 7500 rpm.
1 - 3 of 3 Posts
