1 - 9 of 9 Posts
I went to a custom muffler shop during my lunch hour (3 actually with all the stops I made
- and had a Mid Pipe made to replace my resonator pipe - decided it would be easier and cheaper to have this done than to buy a TDI bypass pipe - and I was right - took the guy all of like 30 minutes - and cost me all of $60........and the sound is great with my Remus - where there was no real tone before, but I have a nice tone now - not annoying or even very loud - just enough to make me happy - but the sound of the air comming out - especially when chipped is friggin awesome!!!!!!!!! the turbo sound is magnified at least 100% - and it just great.....i think it will get a little louder as time goes on which is ok...
I will try to get a sound and or video/sound clip in the next day or 2 so I can post it - but IMHO - if you guys want a cool sounding system that isn't loud - try the Mid pipe/Remus setup - I like it a lot.....now I just have to do a DP and cat.....here are the before and after pics........
Re: Took a long Lunch - got a Mid Pipe made!! :) (JettaManDan)
Looks pretty good. Do you have something welded to the pipe to make use of the rubber bracket in the middle of the cross support?
When i made mine, i welded a bar to the pipe (perpendicular to the pipe) so the bar would slide into the cross support thing.
Re: Took a long Lunch - got a Mid Pipe made!! :) (SL 1.8T)
quote:[HR][/HR]Looks pretty good. Do you have something welded to the pipe to make use of the rubber bracket in the middle of the cross support?
When i made mine, i welded a bar to the pipe (perpendicular to the pipe) so the bar would slide into the cross support thing.[HR][/HR]​
well - the guy did weld something to the pipe to make it work with the support - not sure though - wasn't allowed in the shop - he actually took the pics for me......there is no vibration or any other noises to whatever he did worked........
Re: Took a long Lunch - got a Mid Pipe made!! :) (John A)
well - i had the car chipped with no exhaust mods at all 1st - and I can say the remus and the mid pipe have made a decent difference from that - so I'd say you'd pick up a few hp or so - and get some better throttle response - basicially I have made my own cat back setup based around the remus muffler -
Discussion Starter · #9 ·
Re: Took a long Lunch - got a Mid Pipe made!! :) (VWTornado)
not mandrel - but he has the proper pipe bender that's almost as good.....none of the inside the bend wrinkles......too bad my wife took the car this morning...
1 - 9 of 9 Posts
