1 - 4 of 4 Posts
yo yo yo ..
i want to stop paying $35 for an oil change.
I think i need 2 tools for the job.
what are they?
And if someone can post the standard protocol for changing the oil?
or if im not looking in the right place. just call me a nooby and point me in the right direction.. thanks guys. much obliged!
Re: Tools for an oil change ??? (jaeone)
you'll need these things:
Those Oil pan things you put on the floor so the oil doesn't flood everywhere
TOOLS:
A Socket: 1/2" or 36mm (POWERBUILT BRAND)
Ratchet: with a 3/8" adapter for the socket (POWERBUILT BRAND)
The Combination of the socket and ratchet are used to take off the oil-filter
Wrench: 3/4"
The Wrench is to take off the oil-pan screw/plug
FYI: the oil-filter for the vr6 is not a usual filter..it looks like a small K & N air filter...
Bought all these things @ PEPBOYS!!
have any questions feel free to e-mail me @ [email protected]
Have FUN!!!
[Modified by bumbota111, 12:28 AM 4-12-2002]
[Modified by bumbota111, 12:30 AM 4-12-2002]
You'll need a torx bit to remove a plastic shroud on the bottom to access the filter.
Unless it's only on the 1.8t for some reason.
EDIT:
Umm.. duh, your oil filter may be in a different location. If it's on the front of the engine behind the radiator you'll need that torx. Sorry about that...
[Modified by smd3, 7:39 PM 4-11-2002]
Re: Tools for an oil change ??? (bumbota111)
I don't want to pick but are you saying a 1/2 in ratchet and a 36mm socket or am I just confused.
What about the socket to take out the drain plug 18mm
[Modified by GmanX, 8:49 PM 4-11-2002]
1 - 4 of 4 Posts
