Status
Not open for further replies.
1 - 6 of 6 Posts
Just thought I would note, you show 22mm socket for strut nut. It's a 21mm.
Bump for the ShopDAP guys with a question:
I saw the ignition coil puller tool above and here.
I can't envisage how this is supposed to pull the ignition coil out. Does the long end fit into the bolt hole on the left side of the ignition coil and clamp to it when you pull up on the lower handle? Can someone enlighten me on its usage, thanks.
Never mind - found an instructional video showing how to use it.
Glad you got your answer. Thanks for checking us out.
1 - 6 of 6 Posts
Status
