For those of you wanting to change out the shifter cable bushings in your TT RS, there is another option available: Torque Solution Shifter Cable Bushings- (Audi TTRS) - TS-SCB-1005-6 - 3561
Torque Solution has their own version of it that’s similar to the 42DD, but not as invasive to install. All that you need to do is remove the oem bushings and slip in the new ones.
I just got done installing mine, and it wasn’t bad at all. I followed northendroid’s diy (thank you!) since the install is the same (minus the drilling, cutting, and sanding).
And of course as a reminder: do this at your own risk, I'm not responsible for any damage that may occur if/when you install these!
