So I just scored this beater for free which, according to the guy that gave it away, is a 1983 Rabbit GTI. The stamped VIN on the edge of the rain tray starts with 1VWZZZ which differs from that on the sticker in the driver's door jamb 1VWDC0. I'm not sure what's up with that - is this normal for these old MK1 cars? Otherwise the VIN checks out as an '83 GTI.
The back story is that this was used as a trainer race car and that the previous owner (now deceased) had been scavenging parts off it. Amongst the many issues the steering is dicked up due to the ignition lock housing being broken off. It has a rear disk brakes conversion but the parking brake cables aren't connected. There is no rear suspension in that the shocks/springs are completely gone and replaced with a bit of square steel tube making it a sort of Hard Tail. I've done some basic research and the engine appears to comprised of an Audi 3A block and 8V head. The timing belt is off which isn't the best thing to find however I haven't cracked it open yet to see what's going on.
The interior is completely gutted so a resto is pretty much out of the question but I'd like to restore the dash and front seats at least. My immediate goal is to sort out the suspension, brakes and steering column so the vehicle can be moved about easily and parked without having to block the rear wheels. As for the drivetrain I'm leaning towards a 1.8T swap if I can pull it off here in California. Here's some pictures to give y'all an idea what I starting with (it's pretty rough):
