1 - 2 of 2 Posts
Hi,
I recently removed my tranny flange and drive axle (passenger side).
I am ready to re-install but lost track of which washers go where.
I regular looking washers, 1 washer that is different - it has 4 part that extend out (it still is round though) - hard to explain -I think it's called a distilled washer, etc.
So do I only need the spring the distilled washer and the dust cap for that part or? and what about the wshers and such needed for the drive axle.
Please help,
Thanks,
mkIIlover
Re: Tranny Flange / Drive Axle install. (mkIIlover)
A normal washer (make sure you use the right one) goes in first, then the spring, then the flange, then the distilled washer, with the middle pointing up, then the circlip (good lick with that bugger) and then the dust cap. Make sure your output shaft seals are good before you put this all back together. HTH
Quote, originally posted by mkIIlover »
Hi,
Please help,
Thanks,
mkIIlover
1 - 2 of 2 Posts
