1 - 20 of 63 Posts
Hi Folks,
I thought I would share this with you.
The credit for this goes to Justin Jorgenson from FB Atlas group.
I have a 2019 Atlas with torque converter noise and decided to address it the same way as some of the dealerships do.
Long story short, you need to install 3 rubber caps that cover the area around the torque converter.
Please check if they are already installed in your car as some models already have them on.
Tools and parts needed:
T25 and T45 bits to remove plastic bottom engine cover
rubber covers:
09P301160
09P301160A
09P301160B
113589
113591
Once you remove the plastic engine cover, you will see the transmission and 3 holes:
113590
The rubber covers are labeled 1-3 and go into the holes accordingly to the reference number in the picture above.
They are different sizes so you won't be able to install them incorrectly.
Here is a picture with the covers on:
113592
Videos:
before:
after:
Videos are not the greatest but if you listen carefully, you will hear the difference. You can barely hear anything with all windows up.
Does it fix the problem? No
Is it worth the ~$45? Yes
Does it make it more quiet? Yes
Totally agree. Glad you were able to find them cheaper!
  • Like
Reactions: bboshart
2019 Atlas SEL V6
[mention]kocyk123 [/mention]thanks! Looks like this will be next on the list.
  • Like
Reactions: kocyk123
Discussion Starter · #8 ·
Some newer models came with it from the factory but mine didn't so I assume 2018 and 2019 didn't for sure.
  • Like
Reactions: Reihenmotor5
Discussion Starter · #10 ·
They most likely did it for that reason. It doesn't fix the issue but it makes the issue more quiet... ;-)
I tried to remove some of the screws to get a look at mine. I was hoping to pull down the cover and peek inside, but no luck. Seems like the front of the cover is tucked into the bumper and needs to be slid rearward to remove it? I didn't get all the way underneath, how many screws are there and how easy is it to remove and then replace the plastic cover? I think that, having a 2019 SEL P with a super noisy transmission groan, it is safe to say mine doesn't have the plugs. For $17 I think I'll roll the dice. Just want to get an idea of how many screws we are talking about and how hard it is to do (especially without a lift or jackstands. I think we all know how challenging some plastic panels are to deal with in today's cars.
2019 Atlas SEL V6
Be good timing to do this along with an oil change. Wonder if the converter runs hotter with the covers installed.
Yea I told my friend about this and I said why would VW make inserts? His reply was why would VW have holes in the casing? Is it to dissipate heat?
Discussion Starter · #14 ·
I think it is the time to pull the OBD11 and do some trans temp testing.
Removing the belly pan is covered in the oil change DIY thread in this forum. It can be done without jacking the car up.
Atlas Cross Sport R Line 2021.5
I am just curios it's only for 2018-2019 Atlas or 2020-2021 need this plugs too?
Can't see them for 2021 CS on ECS Tuning site
  • Like
1 - 20 of 63 Posts
