Thanks bud, this forum is pretty dead and this thread in particular. I pretty much use it to keep a record of my work. ha ha.
I had my fuel pump die on me this week. Kinda strange as I just installed it last year during stage 1. I did run it dry when I ran out of gas recently and that is not good for them at all, so I would guess that had something to do with it. I have checked all the wiring and relays and the pump is not priming when the key is in accessory position 1. Gonna replace the pump with a pump for a 2002 Tahoe. It looks like that is gonna be a direct swap and give me the fuel tank pressure and evap that I will need for SMOG.
Will have to pull the pump to see for sure.
Also replaced my Derale Frame rail cooler this week. When I installed it last year it worked fine. This year when I reinstalled it after the swap it wouldn't seal properly. I ended up tapping out the threads to accept the fitting off the end of the AN hose. It didn't leak for a while and then slowly developed a leak that I couldn't trace at first cause it was so small. Finally found it and ordered the NPT to AN adapters and a new cooler. Took the opportunity to move the cooler into the engine compartment. I think I am gonna mount a LED light bar under the core support where the cooler was.
I also got my lines and fittings in for the trans cooler.
I hooked a little LED up to the thermostat on the cooler that will illuminate when the fans turn on. Just another way to keep track of how things are going on the truck. I also have two sensors on the trans. One below in the pan and one up in the body. I can switch between the two sender locations with the switch in the dash and monitor different temps in the trans.
