1 - 8 of 8 Posts
Re: Trunk Lock mechanism (Jma2248)
You are missing a functional push button trunk release. Replacing it while still keeping the little ball bearing functional is a total beyatch, but doable. That mechanism is a typical weak point.
You are missing the little black clip that is attached to the bar in your picture that has the 2 notches on it ..... nevermind, here is a picture of mine. See the little black T-shaped piece ?
Uhm, no they are the same. That black t-shaped piece has a tendency to pop off at times in which case, when you push the button it does not activate the release. But they are the same
1 - 8 of 8 Posts
